Author Topic: [IC] GMK Modern Dolch Light - GB opening on 02/02  (Read 177272 times)
Offline roostrc0gburn
  • its just plastic
Re: [IC] GMK Modern Dolch Light - GB opening on 02/02
« Reply #400 on: Fri, 31 January 2020, 18:31:28 »
janglad, you gonna have matching rama caps for this set like MoDo?
Yes
any render for these?
Offline janglad
  • qoda.studio
    • Clavier.xyz
« Reply #401 on: Fri, 31 January 2020, 18:32:57 »
Yes
Soon™ , I can say it’s a fan favourite from a previous Modern Dolch version making a comeback tho ;)
Offline prangano
« Reply #402 on: Fri, 31 January 2020, 18:38:50 »
Looking on the groupbuy page on Dixiemech, it lists the profile as "SCULPT: 1-2-3-4-5". Is this correct?
I really hope this is 1-2-3-4 . need to clarify this point.
Woops that’s definitely a mistake, this set is indeed 1-2-3-4-4!
Just curious. Why use R4 for the bottom row instead of 5? The tenders of 9009 R3 with a R5 bottom row look really good.
Offline fishinaspacesuit
« Reply #403 on: Fri, 31 January 2020, 21:06:34 »
That Modern v2... looks like I’m in for 2 kits for 2 boards
Offline nasp
« Reply #404 on: Fri, 31 January 2020, 22:00:03 »
Not a 40's staggered user, but I appreciate you listening to feedback and adding support for minivan users.
Offline PocketAces
« Reply #405 on: Sun, 02 February 2020, 10:13:18 »
Check dixiemech Instagram
