Author Topic: Pro micro breakout board with mount holes  (Read 4773 times)
Offline ju6ju8Oo
« on: Mon, 14 October 2019, 21:49:31 »
I’m finding a better way to build a dactyl manuform.
One problem is the mounting the pro micro (or the usb extension) and the TRRS jack is not ideal. It requires glue.
Are there any mountable pro micro clones?
Or are there any existing breakout boards that connects the pro micro to a TRRS jack, so I can save 4 hand wires?
Any other cool ideas?
Offline nevin
Re: Pro micro breakout board with mount holes
« Reply #1 on: Mon, 14 October 2019, 23:28:02 »
...? incorporate a mount for pro micro into the 3d print?
https://www.thingiverse.com/thing:2640192
use a "panel mount" trrs jack?
Offline 4sStylZ
« Reply #2 on: Tue, 15 October 2019, 09:21:21 »
Here is what I have done for fix my pro micro on the case :
https://www.thingiverse.com/thing:3887436
The pro micro is clipped and don’t move at all.
Bépo user here : AEK64 White linear dampened, XD75 Cherry Blue Jailhoused, TypeMatrix2030 black skin, Lenovo 0B47200 w/ trackpoint, G13, G512. Kensington Expert Trackball & Orbit, Magic touchpad 2.
Offline nevin
« Reply #3 on: Tue, 15 October 2019, 11:27:55 »
wow! very nice work!
Offline Loligagger
« Reply #4 on: Tue, 15 October 2019, 19:28:46 »
I've had a similar idea, since at the moment I use a block glued to the bottom plate to keep the pro micro/trrs jack from moving. There's this build which has a separate piece for the connectors which is then screwed in from the bottom.
However something that clamps or is a friction fit with the front wall so that it keeps the pro micro/trrs jack from moving but is easily removable would be ideal to me (somewhat like this). Whenever I get around to it I'll see if I can design a holder & modify the case to accommodate it. I'll likely post it in the dactyl-manuform thread if it works out.
