Author Topic: Linear Switch Smoothness Comparison  (Read 12223 times)
Offline filcomanfilthy
« on: Wed, 16 October 2019, 09:42:42 »
I am building a linear switch build in about a month or two and was wondering how the following switches would compare: Tealios, Zealios, Roselios, Novelkeys Creams, and Ink Blacks. If you have any other switches that you find worthy of being mentioned please feel free to discuss them :thumb:
Filthy
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Linear Switch Smoothness Comparison
« Reply #1 on: Wed, 16 October 2019, 10:29:26 »
You're overlooking all the best ones! Think contactless, man :thumb: .
Offline Sup
« Reply #2 on: Wed, 16 October 2019, 14:23:51 »
If you could put them in a custom standard PCB i would agree with you  ;D.
current
Coming soon
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Wed, 16 October 2019, 16:15:28 »
That has no bearing at all on the smoothness :p .
Offline mizzoperator
  • "This can't be good for me, but I feel great!"
    • Milk Time: The Mizz Domain
« Reply #4 on: Thu, 17 October 2019, 08:17:18 »
Hall Effect slowly wanders into the room
"hmmmhplhlghlpghgh, i'm smoooooooooooth...pick meeeeeee"
Seriously though, pick a contactless switch like Hall Effects. They're more common than ever thanks to companies like APT and they are very, very smooth. If that's not an option, take a normal rubber dome and chuck it in a bucket of water.
Linears are for linear people. No offense if you use linears.
I prefer tactile switches, I'm reluctantly using the AULA SI-859 and my pronouns are she/her.
Offline yui
« Reply #5 on: Thu, 17 October 2019, 08:31:28 »
no one still makes contactless reed switches? that might solve some of the MX compatible linear flaws. and i guess it could be done with a fully custom board and modified MX just so incredibly tedious to stick magnets on all those stems.
Offline mlev6
« Reply #6 on: Thu, 17 October 2019, 09:32:23 »
for mx switches I would say lubed 3204 early 80s vintage blacks with springs swapped out to ergo (62-68g).
modern ec contactless switches are really smooth too (flaretech), modern hall effect - but those boards are hard to customize as the switches are specifically made for a board/ pcb.
« Reply #7 on: Fri, 18 October 2019, 09:59:59 »
Thank for suggestions
Filthy
Offline RominRonin
« Reply #8 on: Fri, 18 October 2019, 21:04:47 »
I love the way fei switches sound and feel (slightly heavier than reds, lighter than yellows), and although not a lot is written about them online, I think they're great.
Sent from my Moto G (5) Plus using Tapatalk
Offline rora
    • Summitcables
« Reply #9 on: Fri, 18 October 2019, 21:37:32 »
The smoothest linear switch is probably a cherry picked vintage, however gateron ink with the right lube / spring is second to none and the most consistent. Although Sound isn't the best, it's pretty good.
Heavensward
Matrix 8x V2.0 Blue | Matrix 8x V2.0 Tiffany Blue | LZ SE MP | TGR Jane V2 Blue Grey | TGR Jane V2 Pink | TGR Jane V2 CE | Keycult No2, Rev1 | Keycult No2, Rev1 | TGR 910 CE | TGRxSinga Unikorn | Orion V3 | Xeno | Mira SE | Kmac Happy | Kyuu | QXP | LZ CLS H | Poly Singa | TXCP | E6V2 FE
Offline flurryvelvet
« Reply #10 on: Wed, 30 October 2019, 08:09:19 »
What about the Fujitsu leaf springs?
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Wed, 30 October 2019, 08:21:46 »
If you have to lube it, it's by definition not the smoothest, and especially not most friction-free :p .
Sorry guys, no matter what reddit hack job thing is in fashion now (inky zealous pandas?), it simply will not beat a good contactless switch. Heck, I think they might have a tough time even beating FLS (if you can find one NOS).
Offline GlennL42
« Reply #12 on: Fri, 01 November 2019, 23:22:31 »
For the smoothest contact-based/conventional switches of the bunch, you'll probably be looking at Tealios (whatever the latest version is right now) or Geekmaker. I only have experience with Tealios V2 so far but I can attest to their smoothness, they are pretty much the top dog even without lubing. As for Geekmaker, some claim they are smoother than even Tealios stock, but I can't vouch for that since I never tried them before, but they should be on par but at the cost of consistency.
But if you're willing to put in some work (lubing and Cherry hurrhurr picking) you should probably skip the boutique switches like Tealios and just get Geekmaker or other more affordable linear since you can bring them up to near stock Tealios smoothness handily with better acoustic than Tealios at considerably lower cost.
You can consider Optical switches like Flaretech and Gateron Optical as well but keep in mind they are highly constrained by platform and will probably have very limited customizability; seeing that you're planning on a build, this is probably not the best choice.
I've started to think subject of contact switches vs contactless ones are not as black and white as it is, I've recently acquired a Zowie board with Flaretech A and while they are smooth, there really is not much noticeable difference between them and stock Tealios, and Tealios pretty handily beat them in off-center smoothness. So unless Flaretech A is considerably worse than their B iteration, the result is not what I'm expecting of a contactless switches.
So it got me wondering just how much improvement in tolerance and housing/slider smoothness of a top-tier contact-based switches can compensate for additional friction point from the contact? (ie: contact switches with good housing/slider vs contactless switches with average housing/slider) Given that in MX switches, the area of friction between the the slider and contact are still relatively low compare to the area of friction between housing and slider and pretty much all noteworthy contactless switches in the market right now are essentially still just MX design with different working mechanism, it'll be interesting to see people gauge the actual difference between the smoothness brought about by improved housing/slider vs lack of friction from the contact.
« Last Edit: Sat, 02 November 2019, 10:41:32 by GlennL42 »
Offline CanaryRAM
« Reply #13 on: Sun, 03 November 2019, 11:41:09 »
Do you know that Zealios are tactile? That other 3 are in my Top5 linear so... Good choose.
