Author Topic: What is the right spring to make Tealios heavier?  (Read 1644 times)
Offline Genkaz
« on: Thu, 17 October 2019, 01:50:04 »
So far I have noticed that I only like Tealios switches out of the 72 that I tested with a tester.
I have been putting together a custom keyboard and noticed that the Tealios switches are too light for the space bar and the shift keys and some other bigger/function keys.
What is the right spring to mod the switch into being heavier while having it maintain the fantastic feel?
Alternatively you are more than welcome to suggest switch types that I may have missed which were not in this thing: https://kbdfans.com/collections/keyboard-part/products/kbdfans-72-switches-tester-all-in-one
It should probably be at around the same weight as an mx green.
Offline Genkaz
Re: What is the right spring to make Tealios heavier?
« Reply #1 on: Thu, 17 October 2019, 05:54:13 »
