Author Topic: Help finding keycaps.  (Read 7665 times)
Offline g3rain1
« on: Thu, 17 October 2019, 12:13:21 »
Look how nice and thick they are! https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2076
I really want this set, but it doesn't have orth compatibility. Does anyone know of something similar, SA or XDA, uniform, white on black or black on black, thick and weighty and compatible with ortho?
I'm looking to compliment my all white Preonic that has SA Icecaps with a dark one. This Filco set is perfect except for the lack of ortho compatibility
Offline Henrythewound
Re: Help finding keycaps.
« Reply #1 on: Thu, 17 October 2019, 12:23:43 »
Offline g3rain1
« Reply #2 on: Thu, 17 October 2019, 12:53:24 »
Do these work?
https://pimpmykeyboard.com/sa-ice-cap-keyset/
That's what I have already. What I'm looking for is a dark version of this.
Offline Sup
« Reply #3 on: Thu, 17 October 2019, 17:31:31 »
Do these work?
So far i know there is none that is readily available or if there even exists one.
current
Coming soon
« Reply #4 on: Thu, 17 October 2019, 17:58:40 »
Do these work?
Sorry about that, I misread the last line of your post. Good luck
Offline fpazos
« Reply #5 on: Fri, 18 October 2019, 16:12:22 »
Does this suits you?? https://kbdfans.com/products/maxkey-black-doubleshot-abs-sa-keycaps
If you wait it's quite common to see gbs of Gmk WoB keycaps
« Last Edit: Fri, 18 October 2019, 16:31:16 by fpazos »
Offline g3rain1
« Reply #6 on: Fri, 18 October 2019, 23:23:08 »
Unfortunately no, it lacks ortho compatibility.
Offline fpazos
« Reply #7 on: Sat, 19 October 2019, 07:37:39 »
https://matrixzj.github.io/docs/gmk-keycaps/WoB-Hiragana/ This one with 40s kit. Maybe in r/mechmarket
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline Lanrefni
« Reply #8 on: Sat, 19 October 2019, 22:29:03 »
Would these ones work? It's more of dark purple than black though.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #9 on: Sat, 19 October 2019, 22:39:42 »
If you're OK with blanks, this site, https://missing-key.myshopify.com/, has what you're looking for.
