Author Topic: GK84 keyboard with Aluminium Case  (Read 27380 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 18 October 2019, 04:52:17 »
GK84 75% Custom Keyboard
 - Bluetooth+Type-c Dual Mode
  - Full RGB with a dedicated software for programming and RGB lighting.
  - CNC Case
  - PBT 5 Sides Dye-subbed Keycaps (cherry profile)
  - USB type C port
  - Hot-swap for switches (Similar to Holtites). (Allows you to change switches without soldering)
 - Built in 2,500 mAh battery
Offline godofdeath
Re: GK84 keyboard with Aluminium Case
« Reply #1 on: Sun, 20 October 2019, 17:43:37 »
When will just the PCB be released?
If I took this apart will it fit in the ANODIZED ALUMINIUM FLAT CASE?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Tue, 22 October 2019, 03:48:13 »
what do you alu flat case?
We don't have flat case for GK84
Offline menuhin
« Reply #3 on: Tue, 22 October 2019, 04:41:15 »
Nice product, 1 question, 2 wishes, 1 suggestion:
- What is "full RGB"?
Is that RGB underglow, plus RGB backlight per switch?
- I hope it can be programmed by QMK or TMK, as at least as flexible as these to have "HOLD" and "TAP-DANCE"
- I hope a split-backspace is possible.
suggestion:
- If the design use a 0.5u separator from the Arrow cluster and to the right of spacebar fits in 2x 1.25u mods (instead of 3x 1u mods), it will be more trendy, comfortable, and symmetrical.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline godofdeath
« Reply #4 on: Tue, 22 October 2019, 05:59:51 »
I want the GK84 PCB in the alu flat case. I don't need the tall case or the rgb glow from the case it comes with.
Offline pitfermi
« Reply #5 on: Tue, 22 October 2019, 06:41:03 »
does this keyboard have true hot swap support?
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #6 on: Tue, 29 October 2019, 02:43:59 »
What do you mean true hot swap support?
Offline Adelscott
« Reply #7 on: Tue, 29 October 2019, 03:24:44 »
Url not showing on tapatalk
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline KPrepublic
  • * Moderator
    • KPrepublic
