Author Topic: [GB] MAXKEYS VIRTUAL WAR SA KEYCAPS Group buy  (Read 27969 times)
Offline BUGER
  • https://www.instagram.com/buger2501/
« on: Fri, 18 October 2019, 07:41:41 »
Welcome to MAXKEYS VIRTUAL WAR SA KEYCAPS Group buy !!
Here~~    https://kbdfans.com/collections/group-buy/products/virtual-war
The group purchase will end on November 19, and the goods are expected to be delivered on February 19.
Some of the smaller array displays
229018-0" alt="" class="bbc_img" />
229020-1" alt="" class="bbc_img" />
229022-2" alt="" class="bbc_img" />
229024-3" alt="" class="bbc_img" />
229026-4" alt="" class="bbc_img" />
229028-5" alt="" class="bbc_img" />
229030-6" alt="" class="bbc_img" />
229032-7" alt="" class="bbc_img" />
229034-8" alt="" class="bbc_img" />
229036-9" alt="" class="bbc_img" />
229038-10" alt="" class="bbc_img" />
229040-11" alt="" class="bbc_img" />
Thank you!
« Last Edit: Tue, 29 October 2019, 12:27:16 by BUGER »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] MAXKEYS VIRTUAL WAR SA KEYCAPS Group buy
« Reply #1 on: Sun, 20 October 2019, 16:12:45 »
Approved
Offline ChitownM2
« Reply #2 on: Sun, 20 October 2019, 16:48:07 »
Nice looking set. Are there no black R1 INS, DEL, & PG DN for 96 key layouts? I only see white available in the Upgrade 1 kit and since I don't usually put them in that order the color scheme is going to be off.
Offline BUGER
« Reply #3 on: Sun, 20 October 2019, 19:24:19 »
Offline BUGER
« Reply #4 on: Sun, 20 October 2019, 19:26:04 »
Because the white key is standard design, black is additional.
Offline rockydbull
« Reply #5 on: Sun, 20 October 2019, 20:28:31 »
Would have preferred opposite color 1.5u bottom keys but the prices are very good so compromises must be made. Looks like kbdfans doesn't have the new prices thougho
Offline BUGER
« Reply #6 on: Sun, 20 October 2019, 21:06:33 »
Black 1.5 in Novelties-Monster  ;D
Offline piit79
« Reply #7 on: Mon, 21 October 2019, 02:40:01 »
Such great prices and no ortho love... Would have taken just a few caps :(
Any chance something could still be done about it?
« Last Edit: Mon, 21 October 2019, 02:42:23 by piit79 »
Offline rockydbull
« Reply #8 on: Mon, 21 October 2019, 06:03:55 »
Ah ok makes sense. Can you reach out to kbdfans about the prices being higher than what is listed here?
Offline piit79
« Reply #9 on: Mon, 21 October 2019, 06:20:07 »
Not sure what you mean. My problem is there isn't an ortho kit at all for some reason...
Offline BUGER
« Reply #10 on: Mon, 21 October 2019, 06:45:36 »
I have checked. My price is the factory guide price. kbdfans has the right to adjust the final price. I think it is reasonable.
Offline piit79
« Reply #11 on: Mon, 21 October 2019, 07:06:23 »
Hey, how about the ortho kit, is it too late for that? Or could it still be added?
Offline BUGER
« Reply #12 on: Mon, 21 October 2019, 07:18:17 »
Oh, I'm sorry, it's a bit late, and so far, only you have raised this question, maybe next time. Thank you.
Offline rockydbull
« Reply #13 on: Mon, 21 October 2019, 07:41:45 »
Sorry I responded to the wrong post. OP ended up answering the question though and said that kbdfans sets the price and his listed price is the factory guideline for pricing.
Offline consumer
« Reply #14 on: Tue, 22 October 2019, 22:21:30 »
I thinknthis set will look nicer with a more uniform profile
Offline BUGER
« Reply #15 on: Tue, 29 October 2019, 12:28:51 »
Added some relatively small display of arrangement, only last 10 days.
Offline pej21
« Reply #16 on: Tue, 19 November 2019, 12:45:50 »
Hopefully, I can get a reply before the group buy ends today.
So is the color orange or yellow? I've seen some posts on reddit saying it's yellow, but it looks orange to me?
Thanks in advance.
Offline elguey
« Reply #17 on: Tue, 19 November 2019, 12:57:28 »
Thanks in advance.
It should be using the same yellow (YBP) used in SA Symbiosis 2.0. Here is a link for recent reddit posts with Symbiosis https://www.reddit.com/r/MechanicalKeyboards/search/?q=symbiosis&sort=new&restrict_sr=on&t=all
Offline JackieX
« Reply #18 on: Fri, 29 May 2020, 10:31:57 »
Sorry. Any update?
