Author Topic: Shark 40% Ortholinear PCB  (Read 19445 times)
Offline Wood_Cables
    • Wood/Cables
« on: Sat, 19 October 2019, 15:30:38 »
$40 for the PCB, shipping is through USPS First Class, anywhere in the world. For an extra $10, get a custom cable (with limitations) made by Wood/Cables (me).
$12 for the Basic Kit (sandwich style) so you can get to using the Shark immediately. Hardware/rubber feet included.
www.woodcables.com/shark
PCB Details:
- ARM Cortex M4-based STM32F303 processor.
- QMK firmware compatible (will be shipped with default firmware pre-flashed).
- USB Type C.
- RGB Under-glow through intelligent integrated controller WS2812B LEDs.
- Full-Grid, One 2U or double 2U space-bar layouts supported.
- 19mm switch spacing. YOU CAN USE YOUR PLANCK SWITCH PLATE.
- Rotary encoder locations at bottom left/right of PCB. Single use only.
- Push button reset.
- Over-current and over-voltage input protection through a fuse and schottky diode.
- Electrical Static Discharge (ESD) protection through a discharge net.
- Ships with hardware necessary to mount into Planck Hi/Lo cases.
Cable Details:
- Custom made by me with every order.
- Choice of Black cord/Black heat shrink, White/White or Gray/Black.
- Straight - 4 Foot.
- USB 2.0 compliant.
- If no color option is selected, Black/Black will be shipped with PCB.
« Last Edit: Thu, 05 December 2019, 13:12:13 by Wood_Cables »
Offline Wood_Cables
    • Wood/Cables
Re: Shark 40% Ortholinear PCB Black Friday Sale
« Reply #1 on: Sat, 23 November 2019, 15:45:13 »
Bump.
