Author Topic: Glorious GMMK  (Read 7346 times)
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Glorious GMMK
« on: Mon, 21 October 2019, 12:26:13 »
I'm thinking of saving up for this keyboard, do you know what switches it supports?
Can it support 3 pin and 5 pin?
Just my thoughts
Offline vincevelorn
  • Great googly moogly!
Re: Glorious GMMK
« Reply #1 on: Mon, 21 October 2019, 12:54:46 »
Only 3 pin switches will fit, you would need to clip the PCB mounted switches to be 3 pin.
VE.A Acrylic Clone, Zealios v2 67g, GMK DMG | KBD75v2, Kailh Pro Purple, Tai hao Blue/Gray | YMD96, Hako Royal Clears, JTK Orange on White
Offline Sintpinty
    • My Roblox Profile
Re: Glorious GMMK
« Reply #2 on: Mon, 21 October 2019, 17:17:34 »
Ok thanks
Just my thoughts
Offline treeleaf64
    • treeleaf64
Re: Glorious GMMK
« Reply #3 on: Thu, 24 October 2019, 11:49:53 »
Cherry MX switches, and MX compatible.
Everyone must pay the cat tax
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Glorious GMMK
« Reply #4 on: Thu, 24 October 2019, 11:58:40 »
AFAIK it will support any MX style switch since the switch LEDs are low profile enough to be flush with the PCB. So the switches do not need to be SMD LED compatible, although using switches that have solid colored bottom housings will basically render the in switch LEDs useless. Switches like Zealios that only come in PCB mount (5 pin) can be made to work with the board by clipping the 2 plastic legs off the bottom of the switch. With other switches you'll want to get the plate mount (3 pin) variants just to make your life easier.
Offline Deadboy
  • I have a bad feeling about this.
    • KN1GHT
Glorious GMMK
« Reply #5 on: Thu, 24 October 2019, 12:07:37 »
I’ve got it with Aliaz switches (5pins) had to cut the legs like said.
« Last Edit: Thu, 24 October 2019, 12:11:56 by Deadboy »
Offline Sintpinty
    • My Roblox Profile
Re: Glorious GMMK
« Reply #6 on: Fri, 25 October 2019, 11:45:07 »
How would i chip that
Just my thoughts
Offline Venaros
Re: Glorious GMMK
« Reply #7 on: Sat, 26 October 2019, 14:35:21 »
With flush cutters or a nail clipper.
Offline mizzoperator
  • "This can't be good for me, but I feel great!"
    • Milk Time: The Mizz Domain
Re: Glorious GMMK
« Reply #8 on: Mon, 28 October 2019, 08:40:26 »
It doesn't support enough pin types to really be viable unless you LOVE MX switches and their various clones.
Linears are for linear people. No offense if you use linears.
I prefer tactile switches, I'm reluctantly using the AULA SI-859 and my pronouns are she/her.
Offline Sintpinty
    • My Roblox Profile
Re: Glorious GMMK
« Reply #9 on: Mon, 28 October 2019, 12:24:57 »
Aight thanks
Just my thoughts
