Author Topic: Questions about hot swap keyboards  (Read 4861 times)
Offline ergonaut
« on: Mon, 21 October 2019, 15:46:00 »
Hi,
I’m thinking about getting a hot swap keyboard (the XD75RE), partly as a secondary keyboard for home use and partly as a switch  testing device. But I think I have read somewhere that there are certain limitations in terms of which switches can be used in the hot swap sockets, something about plate vs PCB mounted. Could anyone tell me which switches can be used on that board? I’m specifically interested in trying Cherry blues and Kailh box whites, but maybe also some Gaterons.
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Questions about hot swap keyboards
« Reply #1 on: Mon, 21 October 2019, 16:24:38 »
Hi,
While Kailh HS sockets do indeed block the holes for on the PCB for PCB mount switches, this is actually not a problem at all. Because firstly almost every switch out there has plate & PCB mount variants available. Secondly the odd switch out that only comes in PCB mount (Zealios as an example) can easily be made plate mount by clipping the 2 plastic legs off the bottom housing that make a switch PCB mount. For the switches you are interested in though you won't have any issues. Cherry MX blue is available in both plate & PCB mount variants, https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=56. Then all Kailh BOX switches are only made in plate mount, https://novelkeys.xyz/collections/switches/products/kailh-box-switches?variant=3747940106280.
Edit: The real issue to look out for with HS PCBs is ones that have RGB SMD LEDs under the switches. You need to make sure you get one that has the LEDs sitting flush with the PCB to be able to use any switch with it. If the LEDs rise above the PCB you can only use switches that have cutouts in the bottom housings to accommodate taller SMD LEDs. Hope this info helps you pick something out & GL finding what you need/want!
« Last Edit: Mon, 21 October 2019, 16:30:10 by Rob27shred »
Offline ergonaut
« Reply #2 on: Tue, 22 October 2019, 01:42:22 »
Hey Rob,
thank you so much for your well-informed answer!
I think LEDs won't be an issue, as I don't plan on using any. The PCB apparently has some underglow LEDs, but I suppose those are on the other side.
Offline Rob27shred
« Reply #3 on: Tue, 22 October 2019, 05:19:12 »
Hey Rob,
No problem! Also yes underglow LEDs are on the backside of the PCB so they won't interfere with the switches in anyway.
Offline Venaros
« Reply #4 on: Sat, 26 October 2019, 14:37:16 »
Hi,
Actually, Kailh hotswap sockets don't block the PCB holes. See: NK65
