Author Topic: 3 keys thumb cluster  (Read 13438 times)
Offline ju6ju8Oo
« on: Mon, 04 November 2019, 06:51:14 »
For 3 keys thumb cluster, do you prefer MiniDox/crkbd thumb arc, or the one on iris / atreus 2?
Offline ju6ju8Oo
Re: 3 keys thumb cluster
« Reply #1 on: Mon, 04 November 2019, 06:59:25 »
I might try with this thumb cluster
What do you think?
« Last Edit: Mon, 04 November 2019, 07:38:26 by ju6ju8Oo »
« Reply #2 on: Mon, 04 November 2019, 07:21:17 »
I like the Corne/MiniDox/Iris thumb cluster. The position and angles of the keys fit my hand size perfectly.
I would only have to stretch to hit the top-most of a split 2u key on an Iris. It would have been better to have it under the columns.
« Last Edit: Mon, 04 November 2019, 07:24:48 by Findecanor »
Offline ju6ju8Oo
« Reply #3 on: Mon, 04 November 2019, 07:36:58 »
Interesting, do you mean the meta key in the attachment is too high for you? and it would be nicer if the meta key is moved downwards?
« Reply #4 on: Mon, 04 November 2019, 07:44:20 »
Yes, that one. I would prefer it non-split, or with the Meta key below X and C in this case.
But I don't use columnar keyboards that much, so do please weigh others' opinions higher.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #5 on: Fri, 15 November 2019, 12:19:05 »
What do you think?
Looks uncomfortable but okay
Just my thoughts
Offline Myteethfeelweird
« Reply #6 on: Mon, 13 January 2020, 23:00:43 »
Personally I hate this cluster it makes life really difficult and make you raise your hand
Offline geek128
« Reply #7 on: Fri, 24 January 2020, 06:06:41 »
my absolute favorite (by magnitudes) is the chimera ergo 42 thumb cluster. ok, that's not what you've asked for ;)
Offline Eike
« Reply #8 on: Tue, 28 January 2020, 03:47:42 »
Just a bit of topic, but I am curious what mods you prefer on you keycluster: Strg/Ctrl, Alt/Option and Win/CMD/Code/System etc. or something different like individual macros or something?
I have just ordered a 3-key-cluster (not ready for production yet) and in eager anticipation I wondered what somebody how already experience the 3-key-cluster-lifestyle come up with as usecases.
Offline daerid
    • Rossipedia
« Reply #9 on: Tue, 28 January 2020, 09:04:39 »
Definitely prefer the Corne's thumb layout. 3 keys down there is all I need currently. I don't actually have that top thumb key on my Iris mapped to anything at all
