Author Topic: [IC] SA Skyriter (Launching August 7, 2020)  (Read 84495 times)
Offline rooski15
Re: [IC] SA Skyriter (Launching August 7, 2020)
« Reply #150 on: Thu, 30 July 2020, 09:41:11 »
Depending on the pricing breakdown, it might be nice to see the 2 most used spacebars from the spacebars kit included in the 40s/Ortho kit. As it stands, those two kits are kind of tied together, given very few use a 6.25/7u spacebar.
Just my 2¢.
Edit: nvm, kits are locked I see.
Thanks for the feedback. What I can say, is that when combined, the two kits will be slightly cheaper than your typical ortho/40s kit.
Well that is good to hear! Excited to see it go to GB. :)
Offline Jhambone9160
« Reply #151 on: Sat, 01 August 2020, 01:49:43 »
I'll still buy this but like others, I would of loved a dark green mod option.
Offline Motte
« Reply #152 on: Mon, 03 August 2020, 14:09:02 »
I like those novelties. Nicely done  :thumb:
That deskmat has a very outstanding design, but to be honest it's a bit too much for me :( But I still like how u crafted something off the mainstream which fits the keyset very well!
When do you think you can post some quotes?
Offline cijanzen
« Reply #153 on: Mon, 03 August 2020, 14:16:48 »
Thank you for the kind words and feedback!
I’m not sure pricing will be up until the GB starts but it will be very aggressively priced and should match recent SA sets.
Offline vocal118
« Reply #154 on: Tue, 04 August 2020, 00:48:59 »
no light green 7u spacebar?
Offline rooski15
« Reply #155 on: Tue, 04 August 2020, 00:54:53 »
Only light green spacebars are Ortho - why would there be a 7u
Offline Gower
« Reply #156 on: Tue, 04 August 2020, 01:59:24 »
I agree. I have a dark green build in the works and i absolutely would have grabbed these mods in a similar shade.
Offline Gimbal
« Reply #157 on: Tue, 04 August 2020, 04:31:37 »
Wait a minute, ISO + Norde kit :thumb: This suddenly got very interesting.
Offline Surefoot
« Reply #158 on: Tue, 04 August 2020, 11:27:15 »
This was always very interesting :) Hope the GB really shines, given it's a quite busy month for keyset GB's...
Offline cijanzen
« Reply #159 on: Wed, 05 August 2020, 18:25:29 »
Added pricing to the first post and updated kit renders. Not all vendors have provided pricing yet but you get the idea. GB starts Friday!
Offline Preußens Gloria
« Reply #160 on: Thu, 06 August 2020, 23:00:49 »
I know it's a little late, but I believe the ISO kit is missing the UK ¬ ` key. I'm also not sure what purpose the R3 | / key has. ISO UK doesn't use that key.
Offline lnmq
« Reply #161 on: Thu, 06 August 2020, 23:29:22 »
One day to go. Can't wait.
Offline cijanzen
« Reply #162 on: Thu, 06 August 2020, 23:45:00 »
Oh my! You’re correct. In fact it’s just the recent render update that this went wrong as my keyboard layout editor file has the correct key there and not the “4 $” key. I will get that corrected as soon as possible.
Thank you for your attention to this!
Offline cijanzen
« Reply #163 on: Fri, 07 August 2020, 00:41:14 »
I've updated the ISO kit render with the proper legends now. Thanks again for catching that error!
Offline azzipa
« Reply #164 on: Fri, 07 August 2020, 17:17:30 »
Offline cijanzen
Offline cijanzen
« Reply #166 on: Fri, 07 August 2020, 23:47:51 »
The group buy thread is now open. Please head over for further discussion!
https://geekhack.org/index.php?topic=107955
