Author Topic: What is this connector?  (Read 3551 times)
Offline Conveyorbelt
« on: Sat, 09 November 2019, 05:49:20 »
Hey,
I am currently doing a DIY on a Rapoo V500 Vpro Alloy, and I was planning on replacing the cable. Could anyone tell me what the name of this connector is, so I would be able to figure out what cable I should buy?
Here are the photos, if you need any more just drop a reply: https://imgur.com/6Hhh9Ar
Thanks heaps
Darcy
Re: What is this connector?
« Reply #1 on: Sat, 09 November 2019, 05:53:03 »
Probably a Molex, there are different sizes and number of pins so you need so measure it.  Or it could be the special Filco one.  Either way size is key.
« Last Edit: Sat, 09 November 2019, 06:01:50 by suicidal_orange »
Offline Tactile
« Reply #2 on: Sat, 09 November 2019, 06:49:06 »
REΛLFORCE
