Author Topic: New white Alps board with single-row enter?  (Read 2456 times)
Offline volvo244t
« on: Thu, 10 June 2010, 19:17:09 »
What the title says.  Is there anything besides the Filco Zero, now unfortunately unavailable in the US, that has white clicky Alps copies AND a single-row enter?
The only two clicky white Alps boards I know of sold new are the Solidtek 6600 and the Avant Stellar.  Both of them have an L-enter and the Solidtek is just a poorly built POS in general (solder joint problems, etc.)
So what are my options?
Keychron C2 - box pinks - mt3 jukebox
Keychron K10 - box crystal jades - mt3 dasher
Keychron V6 QMK - gat cap v2 milky yellows - marrs green clones in oem profile?
IBM Model M - 1391401 - blue label - 3/9/93
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #1 on: Thu, 10 June 2010, 19:20:40 »
Good move putting it in your wish list - You should upgrade that to a link to this thread.  Alps aren't my thing of course, so I'll leave this to the wiser denizens.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline volvo244t
« Reply #2 on: Thu, 10 June 2010, 19:26:48 »
Quote from: washuai;191807
Seems a lot of people around here don't like ALPS switches, but I've used them and they're right up my alley.  I've used brown and black cherries on POS 'boards back when I worked in retail.  Browns are too light, Blacks are alright if a tiny bit too heavy but I prefer tactile switches, never been a huge fan of linears.  Never tried blues, but they're supposed to be right near where the browns are in terms of force and they just sound too damn dainty.
I used to have an Apple IIgs keyboard that had yellow clicky alps, too bad it's apple-only (unless someone knows of an ADB > PS/2 converter or an ADB > USB converter that'd allow the keyboard to work on a PC).  I rather liked the feel of that as well.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #3 on: Thu, 10 June 2010, 19:27:22 »
1) New
2) White Alps, copies or otherwise
3) Single row Enter
4) Available
One or two of these will simply always be missing.
Take off the 'new' requirement and your options open up quite a bit.
kishy.ca
Offline hyperlinked
« Reply #4 on: Thu, 10 June 2010, 19:29:21 »
Quote from: volvo244t;191810
You're looking for the Griffin iMate
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline chimera15
« Reply #5 on: Thu, 10 June 2010, 20:10:59 »
Yeah I used my imate with my m1242 on my pc.  I love the low profile alps switches every once in a while. Works great.  You can even use the extended number/function key pad with the imate, which means it supports chains of adb devices.  It's pretty nice.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline bitflipper
« Reply #6 on: Thu, 10 June 2010, 21:53:49 »
The Tactile Pro at least is an option. It's a little pricey and may be a little wonky with Windows:
Is the Tactile Pro Windows-PC Compatible?
The Tactile Pro is compatible with PCs that have USB ports (pretty much all of them). Since it is a Mac keyboard, there are a few quirks:
The Eject key will not work on a PC. The Volume control keys will only work in Windows XP. The position of the Alt and Windows keys are swapped.
Another option is taking a non-clicky Alps compatible board (like the ABS M1, AT101W, AEKII) and modify it with clicky leaf springs or better yet, real complicated white Alps.
Offline volvo244t
« Reply #7 on: Thu, 10 June 2010, 22:04:51 »
Quote from: bitflipper;191873
I primarily use Ubuntu, so no worries there. (All I use XP for is to play Halo)
Offline volvo244t
« Reply #8 on: Thu, 10 June 2010, 22:10:03 »
Quote from: hyperlinked;191813
I forgot all about that.  Now I wish I'd kept the damn thing, oh well, no F-keys and it had an L-shaped enter anyway.
