Author Topic: Set different layout on a terminal Model M (102 key)?  (Read 4134 times)
Offline kelvinhall05
    • LinusTechTips
« on: Tue, 12 November 2019, 15:14:09 »
I've converted my Terminal Model M to USB with a Pro Micro and everything is working fine, but I'm having one problem where some "special" keys like what would normally be Escape or basically all the keys above the arrow keys as well as some of the numpad keys (except the numbers themselves). How can I remap these to what they would be on a normal layout? Thanks!
Offline Tactile
Re: Set different layout on a terminal Model M (102 key)?
« Reply #1 on: Thu, 14 November 2019, 07:26:08 »
This'll be brief 'cause I don't have much time right now:
You remap keys from [something] to [something_else]. Right now you don't know what those keys are outputting. Until you know the [something] you can't remap those keys to [something_else].
I'm guessing you are using Soarer's Converter. Read the doc's, especially the "Codes" and "Trouble" sections. The tool you need is called HID Listen and it can be found here.
Using HID Listen you can see what codes those keys are outputting and then remap them to what you want.
REΛLFORCE
    • LinusTechTips
« Reply #2 on: Thu, 14 November 2019, 14:50:56 »
Yeah, the hard part is that my output for the key where escape would be (setup/attn/exsel) is this (line 1 is pressed down, line 2 is released):
r08 +68 d68
rF0 r08 -68 u68
Offline Tactile
« Reply #3 on: Thu, 14 November 2019, 15:34:00 »
r08 +68 d68
rF0 r08 -68 u68
You can look that up in the "Codes" section of the Doc's for Soarer's Converter.
0x68 is F13
so to change that to escape you'd have this in your *.sc file:
Code: [Select]
remapblock
    F13    ESC
endblock
So, again, read the Doc's.
REΛLFORCE
    • LinusTechTips
« Reply #4 on: Fri, 15 November 2019, 09:20:25 »
r08 +68 d68
rF0 r08 -68 u68
0x68 is F13
Code: [Select]
remapblock
    F13    ESC
endblock
Alright, I've created a remap file but I'm not sure how to flash it since I'm using Manjaro and the scaswr.bat program is written for Windows only. Here's my remap file...is this OK?
Offline Tactile
« Reply #5 on: Fri, 15 November 2019, 09:29:12 »
That file should be ok.
In a terminal window, in the same directory as the *.sc file you need to:
scas remap.sc remap.scb
scwr remap.scb
...and you're done
Just check out the "Tools" section of the docs
REΛLFORCE
    • LinusTechTips
« Reply #6 on: Fri, 15 November 2019, 09:36:57 »
scwr remap.scb
...and you're done
I tried the first command and I just get a bunch of "invalid instruction errors" on every line in the file (even the comment line at the top!). Am I doing something wrong? Lol
Thanks for helping me out btw, I've been trying to find answers for over a week now haha
Offline Tactile
« Reply #7 on: Fri, 15 November 2019, 09:48:15 »
Here's what happened when I did it:
Code: [Select]
C:\Users\Typical User\bin\Soarer\Soarer_Converter_v1.0\tools\Soarer_sctools_v1.0_windows>scas remap.sc remap.scb
No errors. Wrote: remap.scb
REΛLFORCE
    • LinusTechTips
« Reply #8 on: Fri, 15 November 2019, 09:51:12 »
Code: [Select]
I see...I'll try it in Wine CMD instead of a regular Linux console. I'll see if it works
    • LinusTechTips
« Reply #9 on: Fri, 15 November 2019, 09:53:16 »
Yup, that worked. Should I do the SCWR command now?
    • LinusTechTips
« Reply #10 on: Fri, 15 November 2019, 09:55:41 »
Unfortunately the SCWR command returned this error:
Code: [Select]
003d:err:module:import_dll Library rawhid.dll (which is needed by L"Z:\\home\\kelvin\\Downloads\\scwr.exe") not found
003d:err:module:LdrInitializeThunk Importing dlls for L"Z:\\home\\kelvin\\Downloads\\scwr.exe" failed, status c0000135
Offline Tactile
« Reply #11 on: Fri, 15 November 2019, 09:56:23 »
SCWR remap.scb
...and you should be finished
REΛLFORCE
Offline Tactile
« Reply #12 on: Fri, 15 November 2019, 09:57:50 »
Code: [Select]
What Linux distro?
REΛLFORCE
    • LinusTechTips
« Reply #13 on: Fri, 15 November 2019, 10:01:09 »
Code: [Select]
What Linux distro?
Manjaro. I tried using the Linux SCWR program and I got an error that I was missing the libusb-0.1.so.4 library but trying to install it with Pamac doesn't work (libusb-0.1.so.4 not found).
Code: [Select]
/home/kelvin/Downloads/scwr: error while loading shared libraries: libusb-0.1.so.4: cannot open shared object file: No such file or directory
    • LinusTechTips
« Reply #14 on: Fri, 15 November 2019, 10:05:33 »
Looking in /usr/lib/ it seems that I do have the libusb-0.1.so.4 library but it still doesn't work. Tried with sudo and got the same error.
    • LinusTechTips
« Reply #15 on: Fri, 15 November 2019, 10:08:55 »
I tried one more thing which was to move scwr and remap.scb to the /usr/lib folder and running the command from there but I got the same error.
    • LinusTechTips
« Reply #16 on: Fri, 15 November 2019, 11:21:32 »
Figured it out. I had to install the 32-bit libusb-compat and then it let me flash it. Works great now. Thanks!
Offline Tactile
« Reply #17 on: Fri, 15 November 2019, 11:41:21 »
 :thumb:
REΛLFORCE
