Author Topic: 2019 BFCM KPrepublic Shopping Week  (Read 19202 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 13 November 2019, 00:56:40 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: 2019 BFCM KPrepublic Shopping Week
« Reply #1 on: Wed, 13 November 2019, 00:58:41 »
Egyptian 9009
sale code = bfcm2019-2
Based on GMK 9009 colourway, compatible with Cherry MX switches and related clones, these keycaps are made of super-durable PBT plastic. The all-in-one option only $39.9 for BFCM2019
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Wed, 13 November 2019, 00:59:17 »
TBKB mechanical keyboard kit
sale code = bfcm2019-6
87-key layout
Cherry mechanical switches
Dual IC processing chips
Multimedia controls
21-key rollover with USB, N-key rollover with PS2
Windows key disabled in GAME mode
Fully compatible with Windows
LED backlighting(you need to mount 3mm LED by yourself)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #3 on: Wed, 13 November 2019, 01:01:16 »
ProTouch Pad
sale code = bfcm2019-5
Measurements (multi-touch): 105x70 mm
Measurements (product): 450x120x21x(7) mm
Multi-touch support
Compatible with universal systems
