Author Topic: TRRS Jack  (Read 5076 times)
Offline ju6ju8Oo
TRRS Jack
« on: Wed, 13 November 2019, 07:40:58 »
There're a lot of split keyboards using PJ-320A. Why isn't PJ-313B used instead?
If PJ-313B is used, the position of the TRRS Jack will be the same on both left hand and right hand.
Offline piit79
Re: TRRS Jack
« Reply #1 on: Wed, 13 November 2019, 08:21:09 »
What do you mean by that?
Re: TRRS Jack
« Reply #2 on: Wed, 13 November 2019, 19:29:41 »
Not sure what you mean about the position but PJ-313B is a 5 pole TRRRS connector and you only need 4 connections so that's one reason not to use it.
Ignore me, I'm too stupid to be trying to help at the moment :'(
« Last Edit: Wed, 13 November 2019, 20:11:39 by suicidal_orange »
Offline ju6ju8Oo
Re: TRRS Jack
« Reply #3 on: Wed, 13 November 2019, 20:04:42 »
This should be a 4 pole connector?
Offline ju6ju8Oo
Re: TRRS Jack
« Reply #4 on: Wed, 13 November 2019, 20:24:30 »
I think the 313B jack has a longer footprint, but it’s narrower (for flippable PCBs).
Another cool thing is symmetrical.
Offline ju6ju8Oo
Re: TRRS Jack
« Reply #5 on: Wed, 13 November 2019, 22:17:09 »
please see the attached silks for PJ-320A 230001-0230003-1
If PJ-313B is used, the Y-offset can be avoided.
Re: TRRS Jack
« Reply #6 on: Thu, 14 November 2019, 00:30:51 »
I think it's just because of availability. I can't find this one at any larger component store when I search for it.
However, if designers of split keyboards would instead mirror and panelise their designs then having a symmetric connector wouldn't be an issue. A panelised PCB design might even be cheaper to produce if the halves have a weird shape that could interlock inside a rectangle.
BTW. The TRRS connector had been chosen because it is compact, which was important for a case of layered acrylic  when you want to use as few layers as possible. It is common for it to glitch, and you get noise if you turn it.
If split keyboard cases instead were made with tenting, there would be more vertical space under the raised side of each PCB for a more reliable connector: mini-DIN, 4p4c or even one of those aviation sockets that seem to be so popular right now...
« Last Edit: Thu, 14 November 2019, 00:34:38 by Findecanor »
Offline ju6ju8Oo
Re: TRRS Jack
« Reply #7 on: Thu, 14 November 2019, 02:06:36 »
You're right. There aren't many sellers who sell PJ-313B even on AliExpress.
