Author Topic: Questions about first build (HHKB layout, 60%)  (Read 4805 times)
Offline benfrain
    • benfrain.com
« on: Wed, 13 November 2019, 08:59:17 »
I'm looking to get together pieces for my first build so I'm trying to soak up as much information as possible. However, I'd like clarification on a few points.
My daily board is a HHKB Pro 2 at the office and a WASD v2 at home. Looking to build a new board with a HHKB layout as I'm a big fan but would like a more substantial case and to try some other switches.
Requirements:
- USB C connector
- hot swappable PCB
- metal/alu case
I intend to get a hot swap PCB so I can hopefully buy less keyboards and simply buy new switches instead!
Questions:
1. Can anyone recommend a decent affordable 60% case that would fit the HS60 PCB https://groupbuys.mechboards.co.uk/shop/hs60-hotswap-60-pcb/ that mechanical keyboards stock?
2. I've seen inexpensive cases like this: https://kbdfans.com/collections/60-layout-case/products/customized-gh60-aluminum-case?variant=538568785933 but what do I need to go on top? A plate of some sort? 3. If I want HHKB layout do I need to source something special?
4. Shopping list wise, what do I need? Case, PCB, Plate, Switches, Stabilisers — am I missing anything else?
5. Are cheaper cases a false economy? Do they flex/have poor fitting etc?
Thanks for any pointers!
Offline MMKB
Re: Questions about first build (HHKB layout, 60%)
« Reply #1 on: Wed, 13 November 2019, 12:24:39 »
To have the HHKB layout the case must have two blockers. Best entry level examples I could think of are:
Kbdfans HHKB Tofu
Duck Sidewinder https://geekhack.org/index.php?topic=103356.0
Offline MMKB
« Reply #2 on: Wed, 13 November 2019, 12:28:41 »
- keypuller, switch puller
- band-aid: search “keyboard stabilizer band-aid mod”
- noise dampening sheet such as Sorbothane. It reduces the hollow ping from any metal case
Offline benfrain
    • benfrain.com
« Reply #3 on: Wed, 13 November 2019, 15:56:09 »
Thanks MMKB, appreciate the input 👍
Offline Sup
« Reply #4 on: Wed, 13 November 2019, 16:42:07 »
That case you send is very nice. I got one here and it is low profile, So if you are okay with seeing your switches from the side i think its a good case. Also you would need to find a plate that is specifically cut for a HHKB layout so there are no switch holes on the right and left side of the plate.
current
Coming soon
Offline JinTea
« Reply #5 on: Wed, 04 December 2019, 23:10:17 »
What are other good dampening materials? I know some people use shelf liner as well, don't know the name of the rubber for that either though.
