Author Topic: [IC] FK-5001/9000 calculator replacement  (Read 11584 times)
Offline engicoder
« on: Thu, 14 November 2019, 12:49:06 »
Background
Some time ago, I developed a replacement for the stock, failure prone calculator module in the Focus FK-9000. This project was essentially a "two" off that I made for myself and Chyros. You can see the module on Chyros' youtube channel in his  "Project F" at around the 10:30 mark. In the time since the video was posted several people contacted me expressing interest. I am finally looking at do a small run of these for those who are interested.
Details
The replacement will be a plug in replacement for the stock module and include a OLED monochrome graphic display.  (Some minor modification of the the upper case is require for the display to fit). The module functionality will include:
* Identical functionality to stock calculator including memory
* Selectable RPN input mode
* Persistent clock with date
* Multiple configurable settings for clock format and style
* Eliminates need for stock battery
* Compatible with FK-5001 and FK-9000 that use the single KB/CAL key
Questions for those interested
1. Offline availability: The prototype included a rechargeable Li-on battery in order to support using the calculator when the keyboard is not plugged in and/or the pc is not turned on. For packaging simplicity and cost savings, I am thinking about removing the offline capability and using a simple coin cell to retain clock/date information.
Question: Do you consider offline availability essential even at higher cost/complexity?
2. Case modification The display used on the prototype requires that the plastic ridge that locates the stock display be removed. This modification is simple to perform and does not change external appearance. I have made some inquiries in hopes of finding a display that would not require any modifications and would have a higher resolution.
Question: Does having to modify the case turn you off from this solution? Would you be willing to pay more (~$20) for a display that does not require case modifications and has higher resolution?
3. Older FK-5001 and FK-8000 support: Older FK-5001 models used separate KB and CAL buttons to switch modes and the FK-8000 has a different mounting method and pin header. The module does not currently support these keyboards. If you have one of these keyboards and are interested, let me know. I will investigate adding support.
Pricing
I do not have final pricing yet. Pricing is on the conservative side to avoid surprises. Depending on final configuration, I estimate the cost to be:
Base module ~ $50-60
Offline availability ~ +$15
No mod display ~ +$20
If you are interested please respond or send me a PM with the answers to the questions. Also let me know what you think about pricing.
Offline Rayndalf
Re: [IC] FK-5001/9000 calculator replacement
« Reply #1 on: Thu, 14 November 2019, 17:37:23 »
This is really neat, I don't have a FK-5001, but if I did I'd be all over this (vintage boards in general need more love)
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #2 on: Thu, 14 November 2019, 23:16:38 »
I saw this on Chyros' video and I think it's extremely cool.  I don't own a Focus FK-9000 but if I did I would be all over this. Good luck and hope there's strong support for it.
*Edit, I just realized I almost echoed word for word the previous post without realizing it LOL.
« Last Edit: Thu, 14 November 2019, 23:29:05 by macclack »
Offline Galane
« Reply #3 on: Sun, 08 March 2020, 05:06:33 »
If you could add a way to send the calculator data to the computer, like the FK-9200 can, I'd be very interested in this as an upgrade for the two FK-9000's I own. My keyboards are from 1984 and have a switch on the top edge for PC or AT mode.
An even cooler upgrade would be to expand the macro recording length to at least match the FK-9200's 20 characters, if there's any way possible to do that.
Offline TeacherGeek
« Reply #4 on: Thu, 14 May 2020, 23:42:16 »
Ooooof
Is this going to happen?
Offline IBMweMissU
« Reply #5 on: Mon, 18 May 2020, 10:35:05 »
You should make a version that integrates to any keyboard.
Offline henryofafrica
    • Old Aulacogen
« Reply #6 on: Thu, 07 December 2023, 15:27:29 »
I have a Focus 5001 with a defunct calculator, and I am interested in learning how your replacement calculator project is coming along.  I really don't care what power source you use; whatever is fine.  If the replacement unit will fit in a 5001, I don't have any problem with minor interior case modifications. I don't need to send calc data to the computer.  Don't need clock or RPN, but those are fine.
I'm in Texas.
How are you coming with this?  Please advise.
Offline Lanes
« Reply #7 on: Wed, 23 October 2024, 15:06:07 »
Hate to necro this but I am also interested. I have a FK-5001 that has a working calculator, but I want one of these to futureproof it.
Lanes
