Author Topic: Keyboard Restoration  (Read 1691 times)
Offline TomahawkLabs
« on: Thu, 14 November 2019, 21:47:50 »
Does anyone have any tips on cleaning vintage coiled cables? I am trying to restore and modernize an Apple AEK 2 coiled cable (converting to Mini USB and USB A).
I am using Isopropyl and a paper towel to remove all the grime I can, but it's tedious. I am worried about the coil losing its springyness from being pulled. Is my best best to just clean it and then reform the coil in the oven using heat tape and a brass bar to form the coil again?
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
