Author Topic: Positioning plate for a hand-wired 65%  (Read 4080 times)
Offline sv650touring
« on: Thu, 14 November 2019, 22:17:34 »
Am I missing something? I'm looking for a 65% plate with stabilizer mounts, but can't find one for sale by itself.
The plate needs to fit 16u width x 5u height.
Google image search produces lots of pictures of 65% plates with plate-mount stabilizers, but I can't find any for sale. It seems like my best option is to buy a cheap keyboard to gut it for the plate.
I'm probably overlooking something.
Offline fpazos
Re: Positioning plate for a hand-wired 65%
« Reply #1 on: Fri, 15 November 2019, 00:51:04 »
Most of plates for plate mounted stabs usually are custom created by its owners. Same for almost any layout with platemount stabs
Enviado desde mi Redmi Note 7 mediante Tapatalk
« Reply #2 on: Fri, 15 November 2019, 10:03:10 »
That certainly would explain it. There are many pictures of 65% plate with stabilizer holes on the Internet. I just can't find any for sale right now, except as part of a kit or complete keyboard.
Is there any option cheaper than buying a cheap 65% keyboard just to cannibalize the plate?  :llama:
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #3 on: Sat, 16 November 2019, 20:09:16 »
Go to: http://www.keyboard-layout-editor.com/ to draft your layout
use "Raw data" from above page and paste here: http://builder.swillkb.com/ to get your plate file. (you have options for Cherry and/or Costar stab)
find a place to manufacture your plate (usually laser-cut acrylic is cheap)
if you want to use Cherry (plate-mount) stab: you need 1.5mm plate or it won't fit.
in the past I have done hand-wiring with 2mm acrylic plate, I have to use “mini hand drill machine” to…ehh… mill the stab area on the plate down to desired thickness.
Costar stab: it's less common than Cherry and it also require 1.5mm but you can just glue it to the stab holes on the plate. (no need to mill the plate down).
Offline fpazos
« Reply #4 on: Sun, 17 November 2019, 05:24:23 »
« Reply #5 on: Tue, 19 November 2019, 16:10:55 »
I was trying to avoid custom plates, mainly because of the cost. Thanks for this info about stab differences.
You've been lucky. https://kprepublic.com/products/60-aluminum-glass-fiber-plate-with-plate-mounted-stabilizerfor-gk64-gk64s-xd64-xd60
That is actually a 60% board (15u width), and what I need is one key unit wider.
I emailed KBDfans, and he let me order just the plate from the TADA68 kit. It costs almost as much as the entire cheapo 65% keyboard from Taobao, but it's still the lowest cost option I could find. Now I just hope that the wide caps lock cutout will play nice with SMK switches.
