Author Topic: Wyse WY-50 Ketboard Cable  (Read 5732 times)
Offline kharma
« on: Sun, 24 November 2019, 17:00:54 »
I have restored a Wyse WY-50 terminal except the keyboard has a cut cable. Anyone have a cable from one of these they might sell? Also need the break key.
Offline rxc92
Re: Wyse WY-50 Ketboard Cable
« Reply #1 on: Sun, 24 November 2019, 21:57:24 »
So much effort for a beat up Cherry.. is it worth it?
« Reply #2 on: Mon, 25 November 2019, 00:35:00 »
He's restoring the full terminal, not just the keyboard. From what I can read, the Wyse 50 uses an unusual 10-pin DIN connector and I suppose it would not be easy to find the pinout either.
Wyse's keyboards from this era are otherwise sturdy and well made. Some of them have thick double-shot keys in DCS profile even. I would clean that though, and possibly retr0bright it.
@kharma: You'd be looking the F15 keycap. The Break key's keycap is in its position. ;)
I know a lot of these keyboards have been scavenged for keycaps and/or switches.
Offline kharma
« Reply #3 on: Mon, 25 November 2019, 07:31:28 »
You're right - gotta put my glasses on!
Offline rxc92
« Reply #4 on: Mon, 25 November 2019, 14:12:18 »
Oh my bad, I should've read more carefully. That's a very cool project then, and I hope OP posts pics when they're done!
Offline catamscott
« Reply #5 on: Mon, 25 November 2019, 14:19:23 »
i'm pretty sure i've got a cable and break F15 keycap, will check when i get home tonight :thumb:
« Last Edit: Mon, 25 November 2019, 14:25:44 by catamscott »
Offline kharma
« Reply #6 on: Mon, 25 November 2019, 14:22:35 »
Thanks - As above I need F15 key instead of break.
Offline catamscott
« Reply #7 on: Mon, 25 November 2019, 20:57:09 »
well, still interested?
Offline kharma
« Reply #8 on: Mon, 25 November 2019, 21:18:44 »
Awesome - how much to send it to me?
Offline catamscott
« Reply #9 on: Mon, 25 November 2019, 22:07:49 »
Hmm, maybe $3? Pm me and we'll get this figured out  :thumb:
Offline kharma
« Reply #10 on: Wed, 27 November 2019, 07:32:37 »
Did you get my PM?
Offline catamscott
« Reply #11 on: Wed, 27 November 2019, 08:41:28 »
Hey sorry, been really busy. Just responded now though  :thumb:
