Author Topic: Suggestions on first high-end build.  (Read 1464 times)
Offline VipermanGT2
« on: Tue, 26 November 2019, 21:40:57 »
So, I'm trying to navigate around this endless pit of options for mech kbs. I'm in the market to put together my first high-end build. I have a couple options. I like the dark red E6.5, but I also really am liking how the Savage65 is looking. Then again, there's the Rama M65-B to consider.
Theme-wise, I like grayscale colors, with pops of other colors(think dark gray, with red legends only on the Enter&Shift). Per-key RGB is a big plus. Give me all the crap for RGB but I try to use it tastefully. Usually with saturation lowered and brightness lowered too...it usually gives a really nice soft effect that looks like actual color on the kb. Trust me, I don't like the whole rainbows shooting outta a unicorns ass thing either. It hurts my eyes.
Hotswap because I'm still interested in picking up new switches that are released, tryin em out, etc.
Can anyone give me some advice between:
E6.5
RAMA M65-B
Savage65
Looking for between a 60-70%. I definitely don't want a full. Too big. Is the Drop Alt High Profile worth it if swapping switches and caps? I just don't think it's in the same tier as the previous 3 I mentioned and others.
Basically looking for some advice on pros/cons. What people like about certain kbs(particularly if you own one or more of the 3 listed above). Dislike.
Any other suggestions on KB's that I may not have mentioned or heard of?
