Author Topic: Case for Ducky One 2 SF?  (Read 6900 times)
Offline slydewd
  • tryhard gamer
« on: Thu, 28 November 2019, 12:16:59 »
Hey, I am new to smaller mechanical keyboards and I was wondering if there are any aluminium/metal cases for it. I don't like the plastic :D
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Case for Ducky One 2 SF?
« Reply #1 on: Thu, 28 November 2019, 12:29:39 »
Nope, because of having 3 nav keys about the arrow cluster there is no aftermarket cades I am aware of that it would work with. If it had the normal 660C layout or even Varmillo's V68 layout you could probably jerry rig one of the metal cases for those to work with a one 2 SF. As it is the only way I could think of getting it into a metal case would be to desolder & get rid of the Pg Dwn switch, then putting it in one of those alum cases for the 660M if you can find one.
Offline slydewd
  • tryhard gamer
« Reply #2 on: Thu, 28 November 2019, 12:53:04 »
Thank you for the help! I haven't decided what keyboard I want yet but I am not confident in my soldering skills :,)
Thought it would be easy to just get a decent enough keyboard and change the bad case ;)
« Last Edit: Thu, 28 November 2019, 12:56:27 by slydewd »
