Author Topic: New to the community  (Read 4177 times)
Offline SaraBailey
« on: Fri, 29 November 2019, 02:15:30 »
How Can We Determine which Models are the Top Vacuum Cleaners?
Vacuum cleaners are familiar with many people because we use them every day. Do you know why I said vacuum cleaners are familiar? The primary function of vacuum cleaners is suction power because people use them to suck dust and dirt from places such as cars, floors, and other surfaces. For example, pet owners do not need to use a broom to collect their pet’s fur because vacuum cleaners can do it in a few seconds. There are two main types of vacuum cleaners–cordless vacuums and corded vacuums. This article will tell you about some essential factors that Best vacuum cleaners in the world should have.
HEPA filter
What does HEPA stand for? It is a High Efficiency Particular Air filter. HEPA must meet all standards for air filters that filter allergens. According to manufacturers, HEPA filters can filter 99.95% of dust according to European standards, or 99.97% of dust according to United States standards. The system can filter all particles larger than or equal to 0.3 micrometers (µm).
HEPA filters are used to clean the air going through many vacuum cleaners. All crumbs and fine dust that can cause asthma and respiratory allergies in humans are not a big problem for HEPA filters. For this reason, allergy sufferers can be confident using vacuum cleaners, and their children also have an ideal living condition.
Suction power
We can quickly say that there is a high level of suction power or a low level of suction power. But, do you know how experts and manufacturers estimate “high” and “low” suction power? Many different specifications have to be analyzed in several ways, by many units as well, such as Watts, Amps, CFM (Cubic feet per minute), and AW (Air Watts).
Suction power is also affected by external factors and internal factors. For example, a vacuum cleaner can run with a higher suction power level if it does not use a HEPA filter. Commercial vacuum cleaners have 200 CFM maximum for suction power. However, the scale can go down if you attach something outside the model.
Others factors that highest rated vacuum cleaners should have:
There are many other factors that contribute to the performance of vacuum cleaners. The appearance and design of vacuum cleaners are also important. Do you want to buy a vacuum cleaner with a wrong impression? Do you think that it is Best vacuum cleaners on the market? The main factor in determining an efficient vacuum is your current situation. It would be best if you base the specific factors on your case to make a decision. For example, you have two dogs and three cats in your home. Will you buy a vacuum cleaner specialized for cars or pets?
Some well-known brands of vacuum cleaners in the market
Let’s look at the list because it may be helpful when you research more about vacuum cleaners.
  • Miele
  • iRobot
  • Black+Decker
  • Honeywell
  • SEBO
  • Nu Tone
  • Eureka
  • Electrolux
Notably, it would be wise if you bought a new vacuum cleaner from a reliable place, such as direct from the manufacturer, agencies of authentic manufacturers, reputable supermarkets and stores, and so on. Using a high-quality vacuum cleaner can increase not only your convenience but also your safety. Fake vacuum cleaners will cost you money, and sometimes, they may cause unexpected injuries or even fire or explosion.
Further Reading: The Top Rated Vacuum Cleaners - Get the Scoop
In conclusion
There is a wide range of vacuum cleaners in the current market. Hence, it is necessary to understand them to be able to choose the most suitable vacuum cleaner for your home. The article gives you a lot of useful information so you can shop vacuum cleaners. Before reading the article, if you wondered: What is the best vacuum cleaner?  I think now you have the answer. Thank you for spending time and reading the article.
« Last Edit: Mon, 30 October 2023, 05:18:02 by SaraBailey »
Offline Insanto
    • Etsy page
Re: New to the community
« Reply #1 on: Fri, 29 November 2019, 02:39:13 »
 :thumb:
Offline JinTea
« Reply #2 on: Wed, 04 December 2019, 20:14:34 »
Hi!
New to the community too! Are you new to the hobby as well? How'd you end up finding geekhack? I just got into the hobby because of my roommate personally, haha
