Author Topic: Misalignment Follow Up  (Read 128862 times)
Offline GMK_Andy
  • * Moderator
    • GMK
« on: Sat, 30 November 2019, 17:40:21 »
I have seen a few sources showing some misalignment in some certain caps in a few sets, I just wanted to make a post to do any follow up to a RCA regarding this issue to keep it as transparent as possible. Expect any follow up to happen here. If you'd like to discuss the issue or have anything to add please feel free. Thanks for helping up make the best product we possibly can!
Offline Prelim
Re: Misalignment Follow Up
« Reply #1 on: Sat, 30 November 2019, 18:02:26 »
thank so much for the follow up Andy! my report is here: https://geekhack.org/index.php?topic=99984.msg2836013#msg2836013
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline upas
« Reply #2 on: Fri, 13 December 2019, 14:36:54 »
It looks like a few folks in the GMK Wavez thread are receiving ESC keys with misaligned "C".
https://geekhack.org/index.php?topic=100063.msg2843572#msg2843572
https://geekhack.org/index.php?topic=100063.msg2843554#msg2843554
Offline jani80k
  • In the hobby for a good time.
« Reply #3 on: Thu, 26 December 2019, 16:42:09 »
GMK Minimal big control key misaligned.
For comparison I will attach the faulty one and a good one from another set.
The 'C' is too high up and the 'o' also looks a bit out of place.
Can be seen here, too. https://geekhack.org/index.php?topic=99624.msg2801436#msg2801436
« Last Edit: Thu, 26 December 2019, 16:44:07 by jani80k »
Offline GMK_Andy
  • * Moderator
    • GMK
« Reply #4 on: Wed, 25 March 2020, 12:15:03 »
Thanks for the pics! These have also been forwarded to the correct people!
Offline bobgr8
« Reply #5 on: Sun, 09 August 2020, 14:56:19 »
Hey Andy, could you comment on the recent 9009 misalignments? Thanks!
Offline bobgr8
« Reply #6 on: Sun, 13 September 2020, 05:25:46 »
Hey Andy, noticed your comment on GMK white wolf, could you also comment here?
My Olivia set is much worse than my 9009.
Do you intend to correct these or we are **** out of luck?
