Author Topic: Help, after desolder and replace new switch  (Read 3416 times)
Offline Sasuak
« on: Sat, 07 December 2019, 07:14:12 »
My keyboard Corsair k63 Wireless.
After i replace new switch, when i press one key it will input one row.
Please help, whats wrong with this?
I already check my pcb board, its all clean without any flux or tin
Re: Help, after desolder and replace new switch
« Reply #1 on: Sat, 07 December 2019, 10:51:21 »
Did you trap the USB cable under a switch pin when you put the case back together?  That would do it.
Or maybe shorting a switch pin to an LED pad?
Offline Sasuak
« Reply #2 on: Sat, 07 December 2019, 11:39:25 »
its not even in the case, only pcb and plate.
what is led pad?
Offline Steezus
  • Keeper of Facts
« Reply #3 on: Sat, 07 December 2019, 12:04:19 »
what is led pad?
For each switch, you would have two holes for the pins, two holes for mounting if your PCB supports and you have PCB mounted switches, and two holes for the LED pins marked by the red circle.
Offline Sup
« Reply #4 on: Sat, 07 December 2019, 14:44:40 »
I think it also good if you show us your soldering.
current
Coming soon
Offline Sasuak
« Reply #5 on: Sun, 08 December 2019, 00:08:11 »
Oh i see, no iam not wrong solder  to led pad.
Here is my solder on the pcb
« Last Edit: Sun, 08 December 2019, 01:08:16 by Sasuak »
« Reply #6 on: Sun, 08 December 2019, 04:20:32 »
I may be being stupid trying to think how diodes work but did you somehow kill the diode connected to both replaced switches?  Check them for continuity then swap the probes - they should only be connected one way.
Doesn't seem likely as your soldering looks great.
