Author Topic: Focus FK-9000 converter  (Read 1992 times)
Offline kelvinhall05
    • LinusTechTips
« on: Sat, 07 December 2019, 16:11:28 »
What plug does the FK-9000 have? Would a simple, cheap converter like this work, or does the board just have PS/2? Thanks!
https://www.amazon.ca/kenable-Mini-Female-Keyboard-Adapter/dp/B01H90H6AU/ref=sr_1_7?keywords=mini+din+to+usb&qid=1575755320&sr=8-7
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Focus FK-9000 converter
« Reply #1 on: Sat, 07 December 2019, 18:43:56 »
The FK-9000 is AT/XT; you'll need an active converter.
    • LinusTechTips
« Reply #2 on: Sat, 07 December 2019, 19:07:39 »
As for the physical connector, is it PS/2? The ebay seller said it was in the messages I exchanged with him.
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Sat, 07 December 2019, 19:27:30 »
No, AT/XT keyboards use the old 5-pin DIN connector.
    • LinusTechTips
« Reply #4 on: Sat, 07 December 2019, 19:30:12 »
What's the cheapest decent converter I can buy? One available in Canada
