Author Topic: BM60 RGB PCB  (Read 21253 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
BM60 RGB PCB
« on: Fri, 13 December 2019, 04:00:29 »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: BM60 RGB PCB
« Reply #1 on: Fri, 13 December 2019, 04:01:16 »
Spec
1\More than 60 keys
2\Supports offline flash app
3\Fully programmable PCB(QMK supported)
4\Full hot swappable switch sockets
5\Full RGB switches Leds(With kinds of LED effects)
6\6 bottom  RGB  underglow leds(pre-soldered)
7\Standard ICSP interface
8\MX Stem support
9\All components of the board have been pre-soldered so the PCB is ready for key switches and LEDs
10\Type C port
