Author Topic: Will these Keycaps fit?  (Read 2283 times)
Offline fxm.eee
« on: Sat, 14 December 2019, 05:00:03 »
I ordered a GMMK with Gateron Reds, since i heard they're good for gaming and smooth. will these Keycaps fit? i chose ANSI layout also any ideas about the quality?
https://www.amazon.de/YMDK-Profile-Schalter-Mechanische-Gaming-Tastatur/dp/B07RH7T982/ref=mp_s_a_1_12?keywords=keycaps%2B61%2Bkeys&qid=1576320292&sprefix=keycaps%2B61&sr=8-12&th=1&psc=1    sorry couldn't change the language.
Offline Venaros
Re: Will these Keycaps fit?
« Reply #1 on: Sat, 14 December 2019, 10:00:36 »
They will fit. They are 1.5mm thick PBT which is nice, but the legends are laser etched, so they won't last that long.
Offline fxm.eee
« Reply #2 on: Sat, 14 December 2019, 13:59:05 »
Thank you  :D should last long tho so not gonna get them. any ideas if there are any good quality keycaps on amazon?
Offline RonLinner
« Reply #3 on: Mon, 16 December 2019, 14:27:54 »
Can this be bought only on Amazon?
Offline treeleaf64
    • treeleaf64
Everyone must pay the cat tax
Offline Venaros
« Reply #5 on: Sat, 21 December 2019, 09:30:25 »
You can buy these on Aliexpress too.
