Author Topic: Two "new" vintage keyboards  (Read 2741 times)
Offline pikapika
« on: Mon, 14 June 2010, 16:11:02 »
someone gave me this one : a mitac (never heard before) , seems it has been used in medical services, very clicky, good typing feeling, ps2 and works well
an old ibm, seems a 5150, found in a trash can in the street, at port, tried an at to ps2 and ps2 to usb and it didn't work, maybe broken or bad adapters
Offline pikapika
« Reply #1 on: Mon, 14 June 2010, 16:35:41 »
well the second has something that really looks like an AT port, i understand better why it doesn't work :-)
tahnsk for the info
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Mon, 14 June 2010, 16:42:44 »
PC, PC/XT, PC/AT all use the same keyboard plug - this so-called "AT" 5 pin DIN.
PC (5150 and variants) and PC/XT (5160 and variants) use the "XT" protocol as we call it with that particular plug.
PC/AT and equivalent use the "AT" protocol as we call it with that same plug.
PS/2 is essentially AT with a smaller plug [strike]that is capable of being combined with the mouse on the same physical plug (there are enough pins and the pinout allows for it).[/strike] Oops, not quite right.
« Last Edit: Sun, 15 August 2010, 23:38:53 by kishy »
kishy.ca
Offline Henry
« Reply #3 on: Mon, 14 June 2010, 17:48:01 »
My ancient Mitac PC clone has an unlabeled Chicony keyboard, and this one looks a lot like a Chicony keyboard too.
Offline pikapika
« Reply #4 on: Tue, 15 June 2010, 07:20:19 »
never had a chicony, so maybe :-)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #5 on: Wed, 16 June 2010, 15:24:17 »
It most definitely is a Chicony, model number and FCC ID match. One of the models with plate-mounted switches. You mostly see the KB-518x variations of these (with at least 3 or 4 different switch types), more rarely the older KB-516x, and KB-520x seems to be the least common.
Using the XT model F would require a protocol translator usually built around a microcontroller, see e.g. kbdbabel.
Offline DryDry
« Reply #6 on: Thu, 17 June 2010, 03:17:51 »
the links have broken
I am not tall,not handsome,but a little bad……
