Author Topic: Romac Macropad not working  (Read 2108 times)
Offline LilGnome
« on: Mon, 16 December 2019, 10:16:36 »
Hey guys!
I finished building my RoMac Macropad, but it's not working. It's getting recognized by the Computer as a Romac+ Input Device and I have successfully flashed it with QMK.
The problem is, it's not registering any keypresses. Not from any key. The reset button on it works though, so the Pro Mirco needs to have a connection with the PCB.
Here's what it looks like so far: https://imgur.com/a/rWSuLia
I have also now soldered the Pro Micro to the PCB, even though the Build Guide said you didn't have to do that. I have also cleaned it up with some Isoprypol, so it looks a little nicer now, and have also tried to redo every solder that looked even a little bit sketchy. I have tried shortening some Pins (Row to Col).
I'm really out of ideas here. I think it's a software Problem? Sadly I don't have my Multimeter atm. I'm thankful for every held I can get!
