Author Topic: change spring on soldered cherry mx switch  (Read 2289 times)
Offline rjohn
« on: Wed, 25 December 2019, 08:59:30 »
Hello, as title says,can i change a spring on a switch without de-solder it?
I am talking about a wasd vp3.
Offline Tactile
Re: change spring on soldered cherry mx switch
« Reply #1 on: Wed, 25 December 2019, 09:03:51 »
You can't open the switch housing while the switch is mounted in the plate. So the answer to your question is no. You'll need to de-solder to remove the switch in order to open the housing.
REΛLFORCE
Offline rjohn
« Reply #2 on: Wed, 25 December 2019, 09:28:33 »
i c ,thanks for the reply.
