Author Topic: PCB design service  (Read 46370 times)
Offline Gtrx
PCB design service
« on: Fri, 27 December 2019, 06:28:23 »
Previous work
Geist rev 1, serenity and other work can be found on my github
Capabilities
  • Any usb port (Usb mini b, micro b, usb C)
  • Single color backlight
  • Cherry MX, CHOC, hotswap, Alps, MX and ALPS footprint choices
  • Boards powered by a pro micro or by an mcu that's soldered on the board, a mcu soldered on the board is required for bigger boards (40%+)
  • Split keyboard PCB
  • OLED display
  • Rotary encoder
  • Rgb underglow
  • Bluetooth with ZMK
  • Per key rgb with ws2812c-2020
Pricing and design process
Currently (2021/8/8 I am pretty much completely free. If you're interested in getting a custom pcb designed, please fill out this form and PM me with the pcb name on discord (Gtrx#1598) Or geekhack to get a quote and time estimate. Note, I'm much more active on discord than geekhack.
« Last Edit: Sun, 31 October 2021, 05:03:08 by Gtrx »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: PCB design service
« Reply #1 on: Tue, 07 January 2020, 11:11:13 »
Approved
Offline Gtrx
« Reply #2 on: Sat, 11 January 2020, 08:37:22 »
Update: I do not do pcb assembly. I suggest finding people on here or mechmarket if you need your pcb assembled by someone else.
Offline Gtrx
« Reply #3 on: Sun, 08 August 2021, 06:18:25 »
Update: I am mostly free once again.
