Author Topic: Adding bluetooth and led's to a Plum87 without either  (Read 3231 times)
Offline tedstriker
« on: Sun, 29 December 2019, 13:00:14 »
I have ordered it and it's on its way. I have been searching for quite a while and I haven't been able to figure out if this was possible or not. I'm good at soldering and taking stuff apart and putting it back together. I also have an Arduino Uno rev 3, a sensor shield, and an allo sparky which is this thing
https://allo.com/sparky/sparky-sbc.html
I also enjoy making new things out of stuff that is laying around.
I started with a drevo caliber with brown switches and am currently using a chattering tesoro gram spectrum that I will be returning.
I'm also planning on trying out 55g domes and looking into alternative keycaps.
Are there any other mods I could do? I really like it when I have a reason to solder.
Could I make a totally new keyboard with the other components I have?
Edit: For bluetooth I know of the sciencetools 35$ adapter. I wanted to try and do a cheaper route though by doing this
https://hackaday.com/2016/09/04/convert-any-usb-keyboard-to-bluetooth/
and also housing the board and battery inside the keyboard
« Last Edit: Sun, 29 December 2019, 13:03:53 by tedstriker »
Offline Sup
Re: Adding bluetooth and led's to a Plum87 without either
« Reply #1 on: Sun, 29 December 2019, 14:36:10 »
No mods exist for this keyboard to make the options possible you want. I know there is not one with RGB and bluetooth in one. But i think its the best you just buy the Bluetooth version if wireless is that important for you.
current
Coming soon
Offline tedstriker
« Reply #2 on: Tue, 07 January 2020, 16:18:21 »
The old versions of the plum 87 definitely have rgb. So the question is do ec switches on the non-rgb version have a place for led's, and are there different controllers in the rgb and non-rgb versions? It doesnt seem to make sense to make two different controllers due to economies of scale, but I could be wrong.
I wanted to do this for fun and to see if i could. its definitely possible. may not be cost effective, but meh.
Im just gonna get the BT-500. I know theres enough space in the case for it and a battery. I'm definitely gonna strip it ( even the usb headers ) and attach directly with wires.
Offline VipermanGT2
« Reply #3 on: Wed, 08 January 2020, 04:36:22 »
I’ve been searching for a BT adapter like that. Is that able to be housed inside a board with enough space and a battery?
Offline tedstriker
« Reply #4 on: Wed, 08 January 2020, 18:27:18 »
yes check these two links. well it depends on which keyboard you have and how much extra space there is in the case.
http://handheldsci.com/kb/
https://www.reddit.com/r/MechanicalKeyboards/comments/due8k6/i_converted_a_wired_mechanical_keyboard_to_be/
