Author Topic: I need help flashing my dz60  (Read 1772 times)
Offline IntrospectiveBeet
« on: Tue, 31 December 2019, 21:25:02 »
Ok so basically i just flashed my dz60 pcb (macos), and upon completion, the underglow turned bright red and the keyboard went unresponsive. This is my first custom build and help would be appreciated.
Offline Sup
Re: I need help flashing my dz60
« Reply #1 on: Wed, 01 January 2020, 07:58:19 »
If its unresponsive and the under-glow is on i am pretty sure its in boot mode. Disconnect it and connect it again and then you should be able to type on it again.
Use this playlist and follow it trough. You should be able to figure it out this way.
https://www.youtube.com/playlist?list=PLYEUsdlqPD2a3kzQgnF98Prj-4IzZJGYG
current
Coming soon
