Author Topic: NEW iRocks Cherry Browns $69 BIN  (Read 3891 times)
Offline ricercar
  • mostly abides
« on: Tue, 15 June 2010, 23:11:32 »
http://cgi.ebay.com/I-ROCKS-KR-6230-BK-Cherry-MX-Mechanical-Keyboard-New-/260597829209
THey show pics with and without asian characters on the key caps. I've asked the seller which version this is.
« Last Edit: Wed, 16 June 2010, 18:15:25 by ricercar »
Offline chimera15
« Reply #1 on: Tue, 15 June 2010, 23:32:40 »
That's the one with the funky /? key huh?
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline aegrotatio
« Reply #2 on: Tue, 15 June 2010, 23:37:06 »
That board's layout is idiotically stupid and would likely drive me to murder.  All they needed to do was put the /? key in the correct place by making the right Shift key a little smaller.
At least the position of the backslash key follows SOME precedent.
What in the world were they thinking?
Daily Drivers: Ducky DK1087XM || DSI ASK-6600 || Rosewill RK-9000 BL, BR, BL, and RE || ABS M1 || Das Keyboard Silent || HHKB Lite and Lite 2 || DSI Big Font (kids love it)
Yearning for: Any ALPS keyboard || Any tenkeyless mechanical keyboard
Permanent collection: Poker Blue and Brown || Adesso MKB-125B || SIIG MiniTouch Geek Hack Space Saver || Chicony 5181 Monterey Blue || Chicony 5191 Clone Cherry Blues || Key Tronic 3600 || Unicomp Endurapro & SmarTrex || A crate of IBM Model M and Model M Space Saving boards || NeXTstation Slab || Amiga 3000 || BTC-5100C black and beige || SIIG MiniTouch Plus black and beige
Retired collection: SIIG MiniTouch Monterey Blue || Razer BlackWidow
Offline Laggy-gaga
« Reply #3 on: Wed, 16 June 2010, 03:45:00 »
I got one from Taiwan which images showed it was free from characters
but it came with character after all.
So do ask the seller about that.
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline itlnstln
« Reply #4 on: Wed, 16 June 2010, 07:28:04 »
If that layout didn't royally suck, I'd be all over it.
Offline lmnop
« Reply #5 on: Wed, 16 June 2010, 07:49:54 »
the Thermaltake Meka is coming out it's a rebranded i-Rocks KR-6230 with Cherry MX Black Linear switches and I am sure the MSRP will be higher than $69.99. I don't think the I-Rocks KR-6230 is that bad if it's used for gaming only.
Offline itlnstln
« Reply #6 on: Wed, 16 June 2010, 09:50:14 »
The Enter key and the / key are the biggest problems.  I would like to have at least one Windows key.  That, and the size of the Ctrl keys is ridiculous.
Offline lmnop
« Reply #7 on: Wed, 16 June 2010, 10:24:06 »
I like it. the Uber Crouch :)
Offline ricercar
  • mostly abides
« Reply #8 on: Wed, 16 June 2010, 18:16:26 »
So what's the big deal about large enter keys?
And what have I revealed about myself by asking?
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #9 on: Wed, 16 June 2010, 19:10:49 »
The biggest thing has gotta be backslash...if you spend ANY amoung of time in a DOS/Windows command line, you need that key to be where you expect it to be, or hammering out file paths takes way longer than necessary.
Making it even worse, if you go for the normal spot and hit Enter instead, you've now got to re-type your entire path (except where the cursor keys can recall the previous command, but this doesn't exist in real DOS).
kishy.ca
Offline EverythingIBM
« Reply #10 on: Wed, 16 June 2010, 19:43:45 »
Quote from: kishy;193820
That's a good point actually.
Quote from: ripster;193822
What's DOS?
It's what your computer uses to boot into windows.
Offline ricercar
  • mostly abides
« Reply #11 on: Thu, 17 June 2010, 02:09:40 »
And the magic answer is ...
Hi this version is without the asian characters. thank you!
Offline itlnstln
« Reply #12 on: Thu, 17 June 2010, 07:28:54 »
I don't mind the big Enter key as much as the relocated / key.  That's just dumb.
Quote from: EverythingIBM;193828
I was going to make a comment about this, but then I realized who posted it and remembered 2 things:
-It's just a troll
-For his computers, it's probably still true
Offline pfink
« Reply #13 on: Thu, 17 June 2010, 11:49:28 »
IIRC you can recall the previous command in most versions of DOS with F3. The later versions of MS-DOS came with a memory resident utility called DOSKEY that enabled arrow key recall and editing.
