Author Topic: Dvorak?  (Read 31389 times)
Offline spremino
Dvorak?
« Reply #50 on: Sat, 10 July 2010, 04:29:27 »
Quote from: DreymaR;194168
I disagree with that fingering scheme above - the row stagger makes it very hard on your left wrist. As mentioned before, use an ISO board and do this:
Bunch of problems solved, at minor cost. If you wish, you can do it with QWERTY too and the benefit will be quite tangible.
I agree. Same mod here.
A long space bar... what a waste of space!
