Author Topic: [IC]Infinikey Comfy | Pricing, Kits, Vendors GB: Sep 25-Oct 9  (Read 71971 times)
Offline peripherry
The prototype pictures look beautiful- I'm in love with the novelties. Also thank you for the latin-only alphas kit, will definitely be grabbing a set :D
Offline SodiePops
This is so cute! Can't wait
Sent from my SM-N960U using Tapatalk
Offline lavethyst
october GB is wonderful news! my wallet can't take too much more keyboard related stuff this summer haha
Offline majes
I love this. Would pick up for sure
Offline Paitupai
This is so cute and lovely! waiting for GB
Offline sobuden
Hi, sorry if this has been asked before but, do you have any plans on having a full hiragana alphas?
Enviado desde mi HD1903 mediante Tapatalk
Offline ghstgrl
  • Are you comfy tho?
There are no plans for a hiragana only alpha set, sorry  :(
Space65 | Thera75 | NIZ TKL | Think6.5 v2 | Lily58
GMK Olivia | Comfy PBT | GMK Yuru
Upcoming:
AE Daedalus | GMK Pink on Navy | GMK Birch | KAT Refined
Offline CrazyAssMonkey
Nice set, it does indeed feel quite comfy  :thumb:
Offline deliciousmango
Looks clean, can't wait for this set!
Offline santela
The color scheme is probably not for me, but this is the first time I've seen a prototype instead of just renders (granted I have not been into this hobby for too long). Great job!
Offline Ja3_420
those mods are a no from me chief.
Offline ghstgrl
:)! Thank you!
Yes! I'm glad more vendors and manufacturers are getting quicker turnaround to make prototypes before GB a possibility. It makes it all easier on the buyers when they can see the colors and the designer to ensure that the product matches their idea :). Thank you.
Thanks for the feedback. There are many great sets out there even if this isn't the one for you.
Upcoming:
Offline noorejji
Will you be trying to correct the mods color? Looks too dark imo.
Offline Eagle Bearer
I love this so much!! Definitely grabbing the entire kit. And it's a good thing the GB is in October. Gonna be broke this month buying 65% keyboards  :p
Offline konstantin
  • Formerly constexpr
Seems sort of odd to keep PrtSc, Scroll, Pause as text when all of the other mods are icons, doesn't it? Perhaps you could do something similar to KAT Hyperfuse for those icons?
Have you looked into making the Backspace and Enter arrows a tad smaller/narrower? At the moment, I find them to be overwhelmingly large compared to the other icons. I think a small change here would go a long way.
I think the trash can Delete icon looks a bit out of place next to the fairly abstract, less detailed icons on the other mads. Have you considered using a short, right-facing arrow similar to the Backspace one for Delete? Something like ⭢ or ▸.
Since the Super and Alt icons are quite abstract, perhaps there's no need to include the 1u ▲, 1.5u ▼ variation? Since practically either icon can stand for either key.
The R3 '@ UK key in the add-on kit needs to have a け sublegend rather than ふ because it's replacing the '"け key.
Speaking of sublegends, consider changing the R1 1u \|ー key in base to \|む, and adding a R1 1u `~ー key. This way, both JIS and regular ANSI split Backspace layouts will be covered (currently only JIS is covered).
Please consider including a 1.75u Fn key (with either ≡ or the “layers” icon) in the add-on kit.
« Last Edit: Mon, 06 July 2020, 06:58:46 by konstantin »
Offline ghstgrl
On the fence. It doesn't quite match the pantone chip I have but it is nice blue that I like. If i can get a proto that matches the pantone I'll make a decision/likely put a poll. I don't want to change the colors if I can't see if they can match it perfectly, if that makes sense. I think there is time but I'll have to talk to TKC and Infinikey on if they can quickly produce a key or a set of keys in that color.
Thanks for the info. I'm actually updating the insert/delete cluster legends as well as adding icon symbols to print/scroll/pause right now. I'll also shorten the backspace and enter as it's been brought up a few times.
Regarding sublegends I saw your guide to Katakana GMK sublegends one but I don't believe there is one for Hiragana? So to confirm:
- Switch out the R1 1u \|ー entirely for \|む?
- Add ~ー - I assume this key wil supplment the missing 1u "ー" key that taking the \|ー out would lead to?
- I can ask to add a 1.75u ≡ or layers icon for sure :).
Thanks for the feeback! I'll post updated legends and hopefully one of the deskmat designs 👀 this week :)
Upcoming:
Offline konstantin
Great :) Also make them a bit thinner and/or make the arrowheads smaller, that will help too.
Thanks for the feeback! I'll post updated legends and hopefully one of the deskmat designs  this week :)
Here is the hiragana one:
(KLE link)
Since your set doesn't use quaternary (top-right) sublegends, you can ignore those.
To answer your questions: Yes, replace R1 1u \|ー with R1 1u \|む entirely. Then add R1 1u `~ー (the light yellow key in the guide). As you said, this will supplant the missing ー key and allow for better JIS coverage.
Edit: updated image
« Last Edit: Sat, 11 July 2020, 19:10:44 by konstantin »
Offline ghstgrl
Updated the main post with some quick updates to some of the icon mods and info about deskmat and cables :)
Upcoming:
Offline SpeakingSilence
I am so in for this set. GB cannot come soon enough.
Offline Shiro
dang, i love it! cant wait to see that desk mat :thumb:
Offline ellybellyuwu
Re: [IC]Comfy PBT - Daisuke Richard Inspired | Updated some legends (July 10)
« Reply #70 on: Thu, 13 August 2020, 23:14:36 »
please please pleeeease can we get this on DailyClack  :-[
Offline lluvia
« Reply #71 on: Mon, 17 August 2020, 10:25:13 »
Wish the add-on blanks/space were the baby blue instead of pink >.>
Offline ghstgrl
« Reply #72 on: Mon, 17 August 2020, 12:06:47 »
I can ask but it looks like TKC has a set of vendors they like to work with and they haven't told me that it'll be different for Comfy :(. But I'll ask!
Upcoming:
Offline unluckygamer
« Reply #73 on: Wed, 19 August 2020, 20:52:52 »
Any images on the desk mats
Offline ghstgrl
« Reply #74 on: Wed, 19 August 2020, 21:16:53 »
There will be soon - hopefully in the next week. Just finalizing how many options we're going with :)! Thank you for your patience.
Upcoming:
« Reply #75 on: Wed, 19 August 2020, 21:33:23 »
Offline taiminhle4920
« Reply #76 on: Thu, 20 August 2020, 00:39:29 »
Do you have any expected shipping day on this set?
Offline ghstgrl
« Reply #77 on: Thu, 20 August 2020, 00:48:51 »
Based on recent Infinikey GBs and what TKC projects, it looks like around 5 months - take into account Lunar/Chinese New Year is in Feb 2021 so that will cause a bit of a delay as well. So a projected eta of March or so.
Upcoming:
Offline ghstgrl
Re: [IC]Comfy PBT - Daisuke Richard Inspired | Deskmat Designs Up (August 13)
« Reply #78 on: Sun, 23 August 2020, 17:14:31 »
Deskmat designs added :)
Upcoming:
« Reply #79 on: Sun, 23 August 2020, 17:33:54 »
Will all 3 of the deskmat be produced?
Offline ghstgrl
« Reply #80 on: Sun, 23 August 2020, 17:37:16 »
Yes, given they meet moq ofc.
Upcoming:
Offline pixelpusher
« Reply #81 on: Sun, 23 August 2020, 18:09:22 »
Wow.  I honestly wasn't very interested in this set, but seeing the photos... Great job! It's beautiful.
Offline konstantin
« Reply #82 on: Mon, 24 August 2020, 08:41:25 »
Hey, checking up on the hiragana legends again :) I see that you updated the \|ー key to \|む and added `~ー, which is great. However, this `~ー key actually needs to be alpha-colored. So here's what you can do:
  • In base: change the `~ー legend to `~ろ (keep it mod-colored).
  • In add-on: change the `¬ろ legend to `¬ー (keep it alpha-colored).
Doing this will ensure that coverage for both ANSI and JIS, as well as ISO-UK, is correct.
Additionally, I still think that there's no need to include both 1u ▲, 1.5u ▼ and 1u ▼, 1.5u ▲ variations since those icons look so generic. Also, the second 1u ● (Ctrl) can be moved from base to add-on since it's only used on 40s boards.
Offline ghstgrl
« Reply #83 on: Tue, 01 September 2020, 21:00:29 »
Thanks for the feedback - how does this look re: hiragana legends and colors?
Upcoming:
Offline konstantin
« Reply #84 on: Wed, 02 September 2020, 13:45:53 »
Everything looks correct :) One tiny detail: the ー sublegend on the `¬ー key should be vertically centered compared to ふ, あ. The pic is tiny, but it currently seems to be top-aligned.
Offline Jakkauli
« Reply #85 on: Wed, 02 September 2020, 13:48:05 »
If only this had a NorDe kit, it would be perfect :(
My favourite looking kit by far!
Offline hyhy2105
« Reply #86 on: Fri, 11 September 2020, 03:44:03 »
omg, this is so cute. Love deskmats and  keyset design
Offline Jsdfbn
« Reply #87 on: Mon, 14 September 2020, 00:46:14 »
am in for that deskmat
Offline ghstgrl
Re: [IC]Infinikey Comfy | Pricing, Kits, Vendors (Update: September 14)
« Reply #88 on: Mon, 14 September 2020, 14:56:40 »
Posted an update. Really sorry to the folks hoping for Latin Alphas kit, maybe next time :(
Upcoming:
Offline sobuden
« Reply #89 on: Mon, 14 September 2020, 15:04:14 »
Will you do any artisan/cable colab?
Offline ghstgrl
« Reply #90 on: Mon, 14 September 2020, 15:38:00 »
No artisans planned but SpaceCables is going to have a matching Comfy cable :) - thanks for reminding me for including that in the update!
Upcoming:
Offline ghstgrl
Re: [IC]Infinikey Comfy | Pricing, Kits, Vendors GB: Sep 25-Oct 9
« Reply #91 on: Mon, 14 September 2020, 19:38:57 »
Ugh updated post again as I was just informed the GB got pushed up a week  :blank: .  GB Starts September 25th and will run til October 9th!
Upcoming:
Offline Owl
« Reply #92 on: Mon, 14 September 2020, 20:11:09 »
This grew on me quite a bit. Might have to pick this up!
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #93 on: Tue, 15 September 2020, 09:51:34 »
I live for this kitty deskmat.
French keyboard streamer
Offline Missingnumber
« Reply #94 on: Sat, 19 September 2020, 08:33:30 »
Damn. No Latin kit and an extra $45 just to get split space bars... I was really looking forward to this one. Hopefully there will be a Kat version one day.
Offline Rx003
« Reply #95 on: Sun, 20 September 2020, 08:17:44 »
Does this come with a packaging box? Or just a plain box?
Offline ghstgrl
« Reply #96 on: Tue, 22 September 2020, 10:31:08 »
It'll have an infinikey box with comfy colors and branding. You can see the box and trays in this post.
Upcoming:
Offline gandalf
« Reply #97 on: Tue, 22 September 2020, 14:28:09 »
Sorry I'm late, but will there be an option without the Japanese letters?
Offline Paitupai
« Reply #98 on: Tue, 22 September 2020, 21:34:29 »
There's no latin kit, explanation on the first post:
After much discussion with friends and fellow designers, looking at poll numbers, and considering my original vision, there won't be a latin kit option for this GB. For those of you curious I consistently got only around 30 folks confirming they want a Latin alpha kit across multiple polls that ranged between 85 to 155 responses. I understand this will disappoint folks and you those of you whose decision to get this set is based on the availability of a Latin alphas kit may no longer want to join. Nevertheless, thank you for your interest and support! Perhaps if this GB does well and the demand for a KAT version is there we can offer a Latin alpha kit next time!
Offline gandalf
« Reply #99 on: Wed, 23 September 2020, 22:13:28 »
Oh so thats what latin kit is my bad and thanks for the answer. I thought latin kit meant the ones with the weird lettering
