Author Topic: Maltron Single Handed Keyboard Drive / Software  (Read 1925 times)
Offline evan123
« on: Tue, 14 January 2020, 04:45:21 »
Hi all,
I recently purchased a second hand Maltron LG1A single handed keyboard. I connected the keyboard to my laptop using a PS2 to USB connector but the windows 10 do not recognise the device. After some online research, I installed the 'DriveFix' program to update all the drives but still the keyboard is not recognised.
Any suggestions as how to resolve this issue?
Many thanks
Offline bananasplit_00
Re: Maltron Single Handed Keyboard Drive / Software
« Reply #1 on: Tue, 14 January 2020, 05:01:44 »
Hello, did you use an active adapter or one of these:
Offline evan123
« Reply #2 on: Tue, 14 January 2020, 07:16:45 »
Hi there,
I used the first adapter seen in your reply message (PS2) and the seller advised that it should work with that.
Should I be using something else?
Evan
Offline yui
« Reply #3 on: Tue, 14 January 2020, 08:11:47 »
For ps2 to usb there are 2 types of adapters, some are passive and directly feed the ps2 clock and data lines on the usb data- and data+ lines and let the keyboard controller deal with it, those can be used with some keyboards that are meant to be used that way mainly in that transitional era from PS2 to usb.
The 2nd option are active adapters which take the inputs from the ps2 keyboards and actively translate them into usb, this kind should be compatible with pretty much all ps2 keyboards (model Ms and Fs can sometime crash the weaker ones).
So if you are using a passive one, your problem is either you are using a green one (meant for mice, different PS2 pin-out) or your keyboard is not compatible, if you are using an active adapter for me it would be that the adapter is either dead or very special and requiring a special driver (usually those things uses USB-HID, and the drivers are included in all modern OSes)
Hope this helps
Offline evan123
« Reply #4 on: Tue, 14 January 2020, 12:14:14 »
Thank you very much for the advice, I'll try the other adapter and hopefully it'll work!
