Author Topic: straw poll: Do you prefer tact switch or regular switch for wheel click?  (Read 11825 times)
Offline Tailslol
this is a small straw poll to show what do you prefer in case of wheel click.
https://www.strawpoll.me/19236691
so what do you prefer as wheel click?
Tact switches :
used by razer and logitech sometime they tend to be stiffer,,are extremely light for the mouse ,have a very low travel and tend to have a low life rating .
Regular Mouse switch:
used in most new gaming mouses,by glorious,finalmouse and xtrfy
they can make the wheel a bit noisy,they can be light or stiff,can have low or high life ratings,have longer travel,are a bit heavier for the mouse.
make your choice and have fun!
« Last Edit: Wed, 15 January 2020, 02:26:05 by Tailslol »
Offline SBJ
  • Tactile pls
Re: straw poll: Do you prefer tact switch or regular switch for wheel click?
« Reply #1 on: Wed, 15 January 2020, 02:52:47 »
Put me down for regular ol' mouse buttons.
Offline Tailslol
« Reply #2 on: Wed, 15 January 2020, 02:55:38 »
same regulars are just better.
« Last Edit: Wed, 15 January 2020, 02:59:30 by Tailslol »
« Reply #3 on: Wed, 15 January 2020, 03:41:43 »
I prefer a real, separate middle mouse button with the same type of light clicky microswitch as the left and right mouse buttons.
If the scroll wheel can not be a speed-adaptive scroll wheel which deactivates detents when moving fast, pressing the wheel down should switch between detents on/off.
« Last Edit: Wed, 15 January 2020, 05:09:19 by Findecanor »
Offline yui
« Reply #4 on: Wed, 15 January 2020, 05:17:03 »
i prefer the regular microswitch cause they are cheap and easy to mod (and it is good they are cheap cause i may have "broken" a few by trying to silent mod them)
