Author Topic: AEBOARDS CONSTELLATION 65%  (Read 318538 times)
Offline aeryxz
    • aeboards
« on: Thu, 23 January 2020, 06:10:08 »
CONSTELLATION by AEBOARDS
www.aeboards.com
The CONSTELLATION started as a conceptual design of a single keyboard case that could offer a granular and personalized assembly experience through multiple mounting methods and unique construction options.
The mounting method (described as how the plate and printed circuit board (PCB) construction is affixed to the case) has always been a focus of discussion, research, and innovation within mechanical keyboard enthusiasts and designer circles.
The CONSTELLATION is designed to offer the freedom to experiment and experience three of the most popular mounting techniques in one board, allowing you to discern what feels and sounds you enjoy most without having too many variables affecting your judgement.
MOUNTING STYLES:
O-Ring Gasket Mount
The ‘O-ring gasket mount’ was originally first seen in some of the very early custom keyboard designs that spawned from the Korean community. As these kits were only made in very small numbers during production, they have become something of a rarity that only very few people have had a chance to experience. Only recently has the O-ring seen a resurgence in popularity, promising unique feel and acoustic attributes. It is believed that the gasket offers unique dampening beneath the plate while also dispersing force through to contact points in the bottom of the case. The O-ring gasket sits between the plate and PCB, and utilises specific PCB cutouts and bottom case standoffs to keep the plate in place. You can install and remove the O-ring by stretching it around the plate and specifically the USB-C port. We recommend that you be gentle while installing this gasket.
Gasketed Sandwich Mount
The ‘sandwich mount’ traditionally involves clamping the plate between the two halves of the case - this typically results in a very sturdy construction that reciprocates with a very clean and distinct sensation on switch bottom out. Although popular, one of the common criticisms is that this bottom out becomes too harsh; the lack of any relief or cushioning results in fatigue from longer periods of typing. By adding a series of gaskets where the plate is clamped, an element of cushioned dampening is added to this mounting style. The result is a fine balance between a typing sensation that feels sturdy and crisp that doesn’t cause as much fatigue as the former over periods of time.  You can try half isolation (where one side, usually bottom, of the plate having this gasket to dampen out the bottom out), or full isolation (both sides of the plate having gaskets). Please be aware of material thicknesses and be vigilant when installing gaskets in both half isolation and full isolation, keeping in mind compression and material density as you decide to install these gaskets. Please ensure you do not have too much gasket thickness and are able to screw the top and bottom pieces of the case together.
Top Plate Mount
Amidst all of the different innovations and designs, top mount has remained one of the tried and trusted mounting designs that many enthusiasts favour due to its consistent feeling and balance between relief and rigidity. The mounting points are placed along the top and bottom perimeter of the plate and screw into the top piece of the case. This allows the plate to flex along its lateral axis giving a nice semi-cushioned bottom out whilst still retaining structural integrity. Top mount was included to act as a control or baseline that builders can use to compare with the O-ring and sandwich mount methods to determine which they enjoy the most.
SPECIFICATIONS
Case Specifications
• Grade 6063 anodised aluminium case
• Clear coated brass weight
• 65% layout with no blockers (fixed layout)*
• 7 degrees typing incline
• Standardised AEBoards rubber feet strips
• Standardised AEBoards gaskets
• Interchangeable accent pieces
PCB Specifications
• Horizontal relief cuts
• Powered by QMK
• VIA Configurator support
• Center USB-C
• Black solder mask
Case Colours
Signature Colours
• Black
• Aegis Navy
• Space Grey
Limited Edition Colours
• Influencer Red
• Limited Edition Vickrey Colour
Availability
CONSTELLATION will be available as an in-stock keyboard kit, with additional add-ons available at time of purchase. We will have several waves of availability: Friends and Family, Early Access and then Public Sale. We aim to have at least 100 units for Public Sale.
It will be vendored through our community storefront - The Keyboard Treehouse.
Our release date is to be confirmed, slated for Q1 2020.
« Last Edit: Mon, 12 October 2020, 10:55:45 by HoffmanMyster »
Offline aeryxz
    • aeboards
Re: [IC] CONSTELLATION 65%
« Reply #1 on: Thu, 23 January 2020, 06:10:58 »
Added: We got some requests for some files for rendering - so enjoy!
https://www.aeboards.com/s/CONSTELLATION_RENDER_FILES.rar
« Last Edit: Wed, 29 January 2020, 03:35:45 by aeryxz »
Offline would?
  • Formerly wouldworks
    • Finder Works
« Reply #2 on: Thu, 23 January 2020, 06:13:41 »
you're insane, this board is insane. You and Solid are too good at keyboard stuff
Offline aeryxz
    • aeboards
« Reply #3 on: Thu, 23 January 2020, 06:15:45 »
don't forget xelus, who does our pcbs!
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #4 on: Thu, 23 January 2020, 06:17:03 »
aww yeh?
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #5 on: Thu, 23 January 2020, 06:18:50 »
Alright alright alright
Offline Capsy
« Reply #6 on: Thu, 23 January 2020, 06:19:00 »
Yes.
Offline nug
« Reply #7 on: Thu, 23 January 2020, 06:19:41 »
ne 6u bottom row avail?
Offline Pwner
  • soon™
    • Ion Keyboards
« Reply #8 on: Thu, 23 January 2020, 06:20:05 »
nice
Offline would?
    • Finder Works
« Reply #9 on: Thu, 23 January 2020, 06:20:15 »
of course Xelus too <3
Offline MuffinCat
« Reply #10 on: Thu, 23 January 2020, 06:21:25 »
Awww yiss
Offline aeryxz
    • aeboards
« Reply #11 on: Thu, 23 January 2020, 06:21:58 »
Right now, we have only made it with our fixed layout. I have intentions to offer more layouts at some point. Note that the plate right now in the prototype doesn't have stepped caps, but we will support it.
If you've got a layout in mind, link it, we'll see what we can do in the future.
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #12 on: Thu, 23 January 2020, 06:22:44 »
wowzers
Offline Scottw
    • ScottW's Boards
« Reply #13 on: Thu, 23 January 2020, 06:23:50 »
Looks great. 👍
Offline upas
« Reply #14 on: Thu, 23 January 2020, 06:24:20 »
very nice, looks great!
Offline futurecrime
  • Get Zooted
« Reply #15 on: Thu, 23 January 2020, 06:27:27 »
Ur so cool
Offline Sissy
« Reply #16 on: Thu, 23 January 2020, 06:27:40 »
Been awhile since I seen a 65 without any blockers.
Really interesting choices with the mounting options. Also like the brass? Spacer separator thing.
Offline aeryxz
    • aeboards
« Reply #17 on: Thu, 23 January 2020, 06:33:51 »
Yeah, the accents?
We'll offer different colours accents so you can match up some of your keysets. For example with my prototype in rose gold: https://imgur.com/a/cOlUTqk
If you've got suggestions for accent colours, then free feel to post. I'm going to get some more colours made for prototypes, so ideally ones that match popular keysets with our signature colours - Black, Aegis Navy and Space Gray
Offline nug
« Reply #18 on: Thu, 23 January 2020, 06:37:29 »
Please support this bottom row in the future
Offline eniigma
    • Storefront:
« Reply #19 on: Thu, 23 January 2020, 06:37:32 »
looks really great! good job guys!
seems like a compilation of all the innovations in this community, which is awesome.
Offline Agilr
  • Never stop achieving
    • Discord Server
« Reply #20 on: Thu, 23 January 2020, 06:39:47 »
nut
Offline aeryxz
    • aeboards
« Reply #21 on: Thu, 23 January 2020, 06:42:49 »
We've been working on it during the EXT65 as well. With EXT65 we were trying different gasket materials as well as positive/negative angle style boards.
For this one, we wanted to give a "baseline" feel with top mount, then allow you to add the gaskets to try out what you want to discover, allowing you to limit other variances so you can get a feel for the differences. The prototypes have been pleasant to build and type on, and I hope that our buyers will also enjoy messing around with it.
Offline keyberzerker
« Reply #22 on: Thu, 23 January 2020, 06:44:52 »
ISO - pls!
Offline phabulous
« Reply #23 on: Thu, 23 January 2020, 06:48:05 »
dis gon b good
Offline Starston3
« Reply #24 on: Thu, 23 January 2020, 06:54:27 »
Cool cool
Offline hottrout
  • I'd Hit Dat Key
« Reply #25 on: Thu, 23 January 2020, 06:56:28 »
No ISO ?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Zeelobby
« Reply #26 on: Thu, 23 January 2020, 07:01:15 »
Man, I dunno. Was waiting for the Noah for a good 65, but this might take the cake. Can't wait to see those LE colors.
« Last Edit: Thu, 23 January 2020, 07:02:58 by Zeelobby »
Offline toastyAU
  • the breadcat
« Reply #27 on: Thu, 23 January 2020, 07:04:44 »
Mate I have been waiting so long. Looks so good, you guys are nutty at what you do, keep pushing the game and please take my ****ing money
Dolphin v3 | En Dash | Hyphen | Isla | Zenith | Jules | HHKB Pro 2
Offline Zeelobby
« Reply #28 on: Thu, 23 January 2020, 07:04:50 »
Does the brass form that full edge? or is it just an insert?
Offline duckboi
« Reply #29 on: Thu, 23 January 2020, 07:07:46 »
good work, this will do well.
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline zakatak
  • no cash
« Reply #30 on: Thu, 23 January 2020, 07:08:42 »
what's the price range?
Offline aeryxz
    • aeboards
« Reply #31 on: Thu, 23 January 2020, 07:11:20 »
No ISO ?
ISO - pls!
Sadly no, right now we are running with one fixed layout. Down the track we may support more. It's more of a case of the plate having too much cutouts for ANSI users (our core market). We would have to make sure that there is enough ISO demand for it, which I'm sure there is, but we're taking one step at a time to minimise risk, since I'm going to front my money to buy the units to get them instock (better experience for the buyer imo, and the future of keyboard buys)
It's an insert (it's called an accent). Example: https://imgur.com/a/cOlUTqk
We want to offer a range of colours so you can mix and match to your keysets. It's not connected to your plate.
Offline victorpre
« Reply #32 on: Thu, 23 January 2020, 07:12:15 »
+1
Offline aeryxz
    • aeboards
« Reply #33 on: Thu, 23 January 2020, 07:14:44 »
I'm aiming for 450-550. Trying to get it cheaper as possible, but for a reference, our previous model the EXT65 was 500.
We've had to buy a bunch of extras to make this work. I've gotten a custom rubber feet which will be standardised across our lineup moving forward (paid for moulds and materials for this). It's the same with the gaskets, we've standardising the sizes moving forward (they are slightly different to the EXT65 gaskets). We'll also be including O-rings.
I'm working on packaging now, so final costs will vary based on what decisions we make for this, as well as doing a bit of IC thread reading to check demand. I'm paying for the units and selling it as an instock product, so I want to minimise the risk on my end.
Offline Zeelobby
« Reply #34 on: Thu, 23 January 2020, 07:20:12 »
Ah, OK, so it's an accent, wasn't sure if it was meant to also weight the board.
Offline wongie
« Reply #35 on: Thu, 23 January 2020, 07:28:54 »
There's been a deplorably too long a dry-spell of 65%s without blockers, so colour me interested!
Offline NRbigfoot
« Reply #36 on: Thu, 23 January 2020, 07:29:37 »
Yes, this is good
HBCP | FLX Virgo | aanzee | Mira SE | Leaf 80 | HHKB pro 1 | qxp | Rukia | IDB60 | equinox | No1Rev1 | Whale | Montage | 268.2 | Anniversary Whale | Jer80 | Evolv
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #37 on: Thu, 23 January 2020, 08:11:40 »
Let's go!
Offline lolafineday
« Reply #38 on: Thu, 23 January 2020, 08:55:15 »
Front height? Looks amazing
Sent from my SM-G975F using Tapatalk
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #39 on: Thu, 23 January 2020, 09:03:47 »
Really good idea on this, and probably some clever internals to make it work. I'll have to see about price and front height before joining.
Offline Cagevaper
« Reply #40 on: Thu, 23 January 2020, 09:49:51 »
Count me in!
Offline DasGnome
« Reply #41 on: Thu, 23 January 2020, 10:16:15 »
Looks like the Verne and No.1 had a baby
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
« Reply #42 on: Thu, 23 January 2020, 10:27:05 »
Yes Please!  :-X
Offline SolidCactus
« Reply #43 on: Thu, 23 January 2020, 11:16:08 »
This is it chief!
Absolutely stunning. Great work and I love the variety of mounting options.
Offline nguyenhimself
« Reply #44 on: Thu, 23 January 2020, 11:18:51 »
As a Mac user, I just want to say thank you for the 1.25 x 3 bottom row. Phew.
So far, consensus tend to indicate that both "O-Ring Gasket Mount" and "Gasketed Sandwich Mount" allow for a softer and more stable typing feel, to the point that they sometimes all fall under the "gasket" bracket.
Since you offer both choices here, I assume you believe these 2 methods lead to significant-enough results, typing feel and/or sound? Can you elaborate a bit here?
Offline lunr
« Reply #45 on: Thu, 23 January 2020, 11:20:57 »
i get hard when i see fixed layout plates.
Offline pixelpusher
« Reply #46 on: Thu, 23 January 2020, 11:24:32 »
In stock 100 public units... so we have around what, 8-11 seconds to purchase one?   :p
Beautiful board with interesting features.  Love it.  I'm sure I won't get one fast enough yet again.
Offline PikaJoyce
« Reply #47 on: Thu, 23 January 2020, 11:40:27 »
Buahaha, I feel the very same. I'm loving this board, just unsure if it's actually possible to get in on it :(
Offline eyedrop
« Reply #48 on: Thu, 23 January 2020, 11:50:45 »
I remembered filling out the friends and family form before.  How would we know if we made it on that list?
Love the innovation.  I am enjoying my EXT65 at the moment while waiting for this.
Sent from my Pixel 3 using Tapatalk
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #49 on: Thu, 23 January 2020, 11:51:44 »
This looks like it will popularise gaskets.
