Author Topic: full-size ortholinear  (Read 6497 times)
Offline hactar
« on: Sun, 26 January 2020, 14:23:47 »
Hi, I'd love to get my hands on a full-size ortholinear keyboard, preferably with mechanical keys.  Function keys, ins/del group, and arrows are definitely required but numpad is a "meh" since I never use it.  Basically 87 keys, minus those newfangled Windows keys.  Is there one like this anywhere?
On here, I found a 3.5 yo post about a poll, and one about this guy going to have one custom-made, but my web searches come up empty.
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
Offline piercejenkins
Re: full-size ortholinear
« Reply #1 on: Sun, 26 January 2020, 14:25:28 »
You could try a cherry rc128
Offline hactar
« Reply #2 on: Sun, 26 January 2020, 14:36:49 »
You've got my interest.  Where would I find such a thing?
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
« Reply #3 on: Sun, 26 January 2020, 14:50:14 »
Here is a picture of mine. https://imgur.com/a/nLPM8Gl
I got it from amazon for $35. Here’s the link;
https://www.amazon.com/Cherry-RC128BM-Grocery-Specialty-Keyboard/dp/B00G4CDCLM
It requires 32bit windows to program it.
Offline fpazos
« Reply #4 on: Sun, 26 January 2020, 15:04:12 »
That's the most crazy orto I have ever seen
Enviado desde mi Redmi Note 7 mediante Tapatalk
Offline hactar
« Reply #5 on: Sun, 26 January 2020, 15:09:26 »
Looks killer.
You can rearrange the keycaps and use loadkeys / xmodmap from Linux, yes?  I don't have access to Windows.  Can you get 2x1 (or wider) keycaps for it?  Different color keycaps?
BTW they still sell it for the same price, which is in "it'll probably work" territory.  I lean toward thinking that, for that price, it's a rubber-dome keyboard.
EDIT:  I speak poor BBCode.
« Last Edit: Sun, 26 January 2020, 15:32:48 by hactar »
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
« Reply #6 on: Sun, 26 January 2020, 15:11:13 »
IDK about Linux.  You can use 2u keys, 3u... etc.
Offline hactar
« Reply #7 on: Sun, 26 January 2020, 15:33:22 »
Worth a try.  Thanks!
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
« Reply #9 on: Sun, 26 January 2020, 16:00:09 »
It comes with cherry blacks. And mine was brand new.
Offline hactar
« Reply #10 on: Sun, 26 January 2020, 16:11:26 »
Drop has a 75 key ortho from time to time.
Cool, I signed up.  Thanks.
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
« Reply #11 on: Sun, 26 January 2020, 16:14:41 »
Here is my xd75re in a dasher d60 case. https://imgur.com/a/xoKWBar It’s my daily driver at work.
Offline hactar
« Reply #12 on: Sun, 26 January 2020, 16:41:15 »
Anyone know how I can implement a mode-switch key on Linux, so I can cram alphanumerics, symbols, function keys, and digits into 75 keys?
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
Offline psxndc
« Reply #13 on: Sun, 26 January 2020, 16:43:21 »
You can do that with QMK and layers. And the keyboard will work on Linux, Windows, and Mac.
Ortho. Always.
« Reply #14 on: Sun, 26 January 2020, 16:43:48 »
I just followed the instructions here for the xd75: https://drive.google.com/file/d/0B36cphsDCP8ZZ09EbzZXclIzWkk/view
Offline hactar
« Reply #15 on: Sun, 26 January 2020, 17:08:50 »
I see that, thanks.  Is there a file I can download and try to extract things from to read?  docx and exe don't do much on Linux.  Maybe I could get Libreoffice to open the docx, but clicking on it does nothing.
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
Offline Lanrefni
« Reply #16 on: Sun, 26 January 2020, 23:18:15 »
If you don't mind a little soldering,the BFO-9000 pcb's can be mounted side by side in a 6x18 grid.
Here's mine in split,just picture it as a single plate
Offline hactar
« Reply #17 on: Mon, 27 January 2020, 00:14:42 »
That's sweet.  I looked at the BFO-9000 kit and it did pique my interest, but I was hesitant because I've never done anything with keyboards except as a unit (plus it's not currently offered).  What all do you need to buy that's not included in the kit?  Obviously keyswitches.  I assume keycaps?  Case?  Cable?  Do you get all the extras from the same vendor, or do you have to shop around?  Does the PCB come as one board which you break apart, or is it always two parts?
Code: [Select]
  pfmlj
qbyurso
kcdtheaz
xgvwni
