Author Topic: Will Teensy++ 2.0 development board fit in the XenGi's Teensy footprint?  (Read 2798 times)
Offline SCWes
Just wondering if I buy https://www.pjrc.com/store/teensypp_pins.html and use https://github.com/XenGi/teensy.pretty for the teensy ++ 2.0 footprint, are the pins small enough on the development board to fit the holes? I would think if the pins go in the teensy to begin with, they must be the same size on the protruding side, no? Just making sure.
Re: Will Teensy++ 2.0 development board fit in the XenGi's Teensy footprint?
« Reply #1 on: Sun, 26 January 2020, 23:54:20 »
Normal header pins may have a square cross-section, but are less than 1 mm on the diagonal, so I think so.
« Last Edit: Mon, 27 January 2020, 00:03:23 by Findecanor »
Offline kkatano
« Reply #2 on: Mon, 27 January 2020, 23:05:25 »
I recently used XenGi's teensy2.0 footprint (not ++ but both seems to have same hole size) on my project. The hole fits teensy's pin well.
Offline SCWes
« Reply #3 on: Tue, 28 January 2020, 00:34:37 »
Great! Thanks for the reply.
