Author Topic: Swap kailh box brown spring for gateron clear spring?  (Read 2737 times)
Offline BlueStar128
« on: Wed, 29 January 2020, 18:32:35 »
So I've been using kailh box browns for about a month now and it's good, but not perfect for me. I just wish it was more lighter, so I ordered a switch tester last week that came with gateron clear and loved it, but wanted some more tactility. I was wondering if swapping the springs would work so that I could have a light tactile brown switch. Or am I just better off buying some new switches entirely?
Re: Swap kailh box brown spring for gateron clear spring?
« Reply #1 on: Wed, 29 January 2020, 18:35:06 »
box switches use different springs so you'd have to get them from somewhere else
gat clear is 35g bottom out i think?
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3551
Offline BlueStar128
« Reply #2 on: Wed, 29 January 2020, 18:42:46 »
Thanks for the info! I'll probably order these sometime this week.
Offline Maledicted
« Reply #3 on: Wed, 29 January 2020, 18:50:50 »
35g is pretty light, could the Box Browns maybe have some return issues at that weight? They're not substantially tactile, so maybe not?
Springs are cheap, so not much risk either way.
Offline BlueStar128
« Reply #4 on: Wed, 29 January 2020, 19:07:08 »
I have some extra box browns, so I'll probably just swap them on one or two and see if they work. If not, I'll just get some heavier springs with 45g and see if those perform better or if they're right for me
Offline Maledicted
« Reply #5 on: Wed, 29 January 2020, 20:37:54 »
I should do the same with some thick clicks, eventually. Good luck to you in your experiments.
Offline areslane
« Reply #6 on: Thu, 30 January 2020, 08:37:06 »
So while I wait for my Tada68 parts and Hako Royal Clears to arrive, I got myself a few switches to play around with to see what I'm missing.
Dafont Showbox Adam4adam
« Last Edit: Fri, 31 January 2020, 07:32:01 by areslane »
