Author Topic: C3 Equalz Tangerine V2 Review + Reviews Meta Update  (Read 15009 times)
Offline ThereminGoat
« on: Thu, 06 February 2020, 20:03:42 »
Hey all,
It's ThereminGoat again - back as usual with a review and a bit more this time. Please follow the normal Google Drive link below to get to the long awaited C3 Tangerine V2 Review. As well, please check out the 2/6 Meta Update which provides a little bit of an explanation as to what is occurring behind the scenes with me as well as plans for the direction I want to take stuff in the future.
As always, I hope you all love them and feel free to reach out to me via Discord at ThereminGoat#2561 and/or through DMs here. Thank you all so much for the love and support, and I hope to continue making you all happy.
Google Drive Link:
https://drive.google.com/drive/folders/109xEdWBEvKmJfLeaMqXuQNnQhKXTdCJg?usp=sharing
Cheers,
-Goat
Offline pixelpusher
Re: C3 Equalz Tangerine V2 Review + Reviews Meta Update
« Reply #1 on: Thu, 06 February 2020, 20:16:32 »
Hey all,
Google Drive Link:
Cheers,
-Goat
Good write-up.  I've had to film every Durock switch I've bought (alpaca, koalas, T1, and V2 Tangerines).  I have these FFF switches on the way.  I guess i need some more films!
Offline Aatlatlatla
« Reply #2 on: Wed, 12 February 2020, 22:16:01 »
Thanks for the reviews!
« Reply #3 on: Sun, 16 February 2020, 13:48:03 »
Thank you guys for the support! Apologies for the delayed response - I only ever really get on Geekhack for ICs/GB posts and forget that I post these reviews here until I drop another one. I hope you guys will continue to check out the new stuff coming as well as my plans for the future.  If it wasn't from the warm support I've had from the community at large (here and on other platforms) I'm not sure I would be able to put out as much content!
Offline nettoxx7
« Reply #4 on: Tue, 07 April 2020, 09:52:54 »
C3 Tangerines are one of the smoothest switches that I have typed on hands down. :thumb:
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #5 on: Tue, 07 April 2020, 10:11:09 »
You are the switch hero @ThereminGoat! Awesome write up as usual, really got me thinking I should wait for these to restock before I build up my new PCB/plate for my e6.5? I'm definitely going linear on it & got a bag of PE stems I was planning on combing with either black Gat bottoms & Cherry tops (filmed & lubed with 205G00). Which do feel very nice on the few loose ones I made to see how they are, but I really want a spectacular linear switch for this build & you sure make a good argument with V2 Tangies being the S-tier MX linear switch right now. What do think of putting PE stems in the V2 Tangie housings? Do you think it would suffer from the same stick/slip issues Creams have because the stems being the same material as the housing?
Offline TyroneZackery
    • liberty slot
« Reply #6 on: Wed, 08 April 2020, 12:36:33 »
Hey all,
Google Drive Link:
Cheers,
-Goat
Really really nice review. Everything is short and clear. I will try to see everything that is on google drive)
Life is a series of choices
Offline gummybur
  • Keep calm and curry on
« Reply #7 on: Wed, 08 April 2020, 23:23:00 »
Thanks for the review! been using your reviews to research my upcomingboards!  ;D
