Author Topic: Please, help with split keyboard flashing (QMK)  (Read 3688 times)
Offline DNLTLM
« on: Fri, 07 February 2020, 09:57:01 »
Hello, I made a keyboard from a github (https://github.com/marksard/Keyboards/tree/master/rhymestone).  And I came across a problem with pro micro firmware(QMK) or pcb.  The left half works fine, but the right half does not work at all, it doesn't work through trrs either (power led is on, but the computer gives an error message when connected, that the device is unidentified, and nothing works) and tried most of the firmware methods, but nothing  helps.  And in Arduino IDE everything works and hid too. Pro micro from the same seller.
