Author Topic: Finding the right TKL PCB.  (Read 3364 times)
Offline Ajchauvet
« on: Fri, 07 February 2020, 12:33:09 »
Hey everyone! Im currently on the lookout for a new TKL PCB to start a new build, but I’ve been having a difficult time deciding which one would be best for my desired build. I really enjoy the TKL style, but I’ve been worried most about finding a decent case that would fit the PCB correctly and wouldn’t break my bank (not trying to be cheap, but I’m sure most know how much some cases can run.) if anyone has any suggestions of a TKL PCB/ TKL cases that are compatible and is QMK compatible I would be eternally grateful!
Thank you!
Offline Fnzzy
Re: Finding the right TKL PCB.
« Reply #1 on: Fri, 07 February 2020, 13:35:58 »
TKL are not nearly as common as 60%. This means that you won't likely be able to just buy a TKL case off the shelf like you could with a Tofu or similar 60% tray mount cases.
That said, if you're looking around on the aftermarket for TKL boards you will most likely find kits that already come with a PCB. If you're trying to make a case yourself (for example stacking laser cut acrylic) your best bet would be an H87A pcb since it will probably fit most cases you can either make or buy.
Here's a handy TKL PCB compatibility chart that covers quite a bit. https://docs.google.com/spreadsheets/d/1GpM--fKeDw_tIDZj4m2jmbMavSyXeOu3QHzfTJwz-IM/edit#gid=0
Offline Ajchauvet
« Reply #2 on: Fri, 07 February 2020, 15:25:43 »
Thank you so much! I really appreciate the response. The goal was to either buy an aftermarket TKL set or buy a PCB and make my own custom case for it. I’ll keep the H87A in mind, it looks like a decent mid range board.
Offline treeleaf64
    • treeleaf64
« Reply #3 on: Fri, 07 February 2020, 21:16:19 »
Wow, thanks for the spreadsheet. This could help the future me... :)
Everyone must pay the cat tax
Offline hasagi
« Reply #4 on: Fri, 07 February 2020, 21:55:57 »
You can look at KBDFans' KBD8x, but from what I heard in their discord channel the next round of group buy will only run in March. Would instantly jump on this if I were not looking for a hotswappable TKL myself haha.
Offline mode
« Reply #5 on: Sat, 08 February 2020, 01:30:28 »
I'm a big fan of LFKeyboards PCBs, You can always get them, and they work nicely with the YMDK case which is cheap and clean looking.
