Author Topic: Rubber Dome Gateway 7000985 ALPS Plate mod  (Read 2639 times)
Offline abrahamstechnology
« on: Thu, 13 February 2020, 14:40:52 »
I was looking through Goodwill when I found this, the switching mechanism was pretty awful and mushy KeyTronic rubber domes, however I noticed the barrelplate was a separate piece and wasn't curved like some rubber dome boards with separate barrelplates, so I figured it would be fairly easy to make a mechanical interior. These boards are fairly common on Ebay as well, plus there aren't many Alps boards around with media keys so this would be fairly unique.
The only thing a bit weird about this board is the profile of the case, probably similar to that of an AEKII with an insanely tall f-key row. The original keycaps had longer stems to compensate, so I'll probably 3D print stem adapters or something.
I'm working on a PCB next.
Offline Techno Trousers
  • ʘ_ಠ
Re: Rubber Dome Gateway 7000985 ALPS Plate mod
« Reply #1 on: Thu, 13 February 2020, 15:30:19 »
Pardon my ignorance, but how will the media keys be integrated in with a new pcb? Interesting mod!
« Reply #2 on: Thu, 13 February 2020, 17:41:15 »
I'm gluing microswitches under the buttons then wiring them to the microcontroller. The PCB will only hold the main switches and Teensy++
Offline Maledicted
« Reply #3 on: Thu, 13 February 2020, 20:47:32 »
Cool. Good idea. I think my aunt and uncle had one of these keyboards. They may yet have it.
Offline rxc92
« Reply #4 on: Thu, 13 February 2020, 21:45:06 »
but WHY
That bezel should be considered a war crime.
Offline Maledicted
« Reply #5 on: Thu, 13 February 2020, 22:14:26 »
but WHY
Not digging the hideous mid 90s aesthetic? That's part of the charm. Just like how I almost modded an XB1 into an 80s VCR chassis, since it already looked as bad as one.
