Author Topic: Lubed my spacebar and now it is sticking  (Read 4671 times)
Offline mithian
« on: Fri, 21 February 2020, 16:39:32 »
Hello,
Today I lubed my keyboard and everything was great until I started typing. I only lubed the stabs btw and I did it without soldering and I used dielectric grease. When I started to type the spacebar started to stick sometimes. Will this eventually stop as the grease gets more worn in? Is there anything I can do rn to help hit>
Offline treeleaf64
    • treeleaf64
Re: Lubed my spacebar and now it is sticking
« Reply #1 on: Sat, 22 February 2020, 09:09:28 »
Hello,
You may have put too much, because it started to stick. Make sure the stabilizers are in the correct positions and not bent at all.
Everyone must pay the cat tax
Offline lolafineday
« Reply #2 on: Sat, 22 February 2020, 14:42:09 »
Yeah you might've put a bit too much and it run to the bottom of the stabilizer.
Sent from my SM-G975F using Tapatalk
